Need some help with lifting...
Old Feb 21, 2010 | 10:52 PM
  #21
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
well im not argueing with you then i am argueing with pavementsucks bc i had an other ram before this one and i was up on 42's and NEVER had an issue offroading.....and trust me i used to beat the ***** off her
Old Feb 21, 2010 | 11:11 PM
  #22
cowboytrucker32's Avatar
cowboytrucker32
cowboy, talk to me about this coil spring deal. Sounds like this might be what I do. Im set on the 35"s though.
Old Feb 21, 2010 | 11:19 PM
  #23
redheadhunter21's Avatar
redheadhunter21
Ok 35's are not the max for stock axles, and you do not need to regear with 35's, and yes you need a lift to fit 35's.
35's are about the biggest tire to run safely on these trucks before going through parts prematurely, yes you can put 37's and bigger but you run the risks of wearing out parts, like u-joints.
If you would like to keep the power and gas mileage your trucks has now you do need to regear but if you can deal with loss of power, and gas mileage go ahead and put 35's if you decide later on that you want your power back then you can regear
Old Feb 21, 2010 | 11:23 PM
  #24
xxxcowxboyxxx
here is the lift on my truck.
i took coils from an 05 cummins 3500.......gained just over 4 inches for the front
for the rear i have 6" blocks. i stacked (2) 3" blocks (welded)
and i also replaced all 4 shocks as they arent really long enouh once you hit 3 inches of lift
i am on 35" pro comp Xterrains and have never rubbed once
now alot of people would deter you from doing a lift like this bc it has no function for offraoding but keep in mind that my truck if mostly show and i dont do anything extreme offroad. if your going to get into offroading you also need to do some swaybad drop brackets, possible long arm kit, drop pitman arm, adjustable trac bar.
personally i love my lift and so do the hundreds of ppl that stop me to talk about it all the time when i take her out. not including the price of the new shocks, i only have roughly 80 $ into my entire 4" lift......your not gonna beat that anywhere
Old Feb 21, 2010 | 11:44 PM
  #25
cowboytrucker32
I like that cowboy. Im going for the same thing you are i guess, i mostly want it to look good but do some off roading, nothing extreem though.
and redheadhunter, bad *** name, and so your sure I wouldnt have to regear? I probibly will eventuialy, but for now, i just want to lift her up.
Old Feb 21, 2010 | 11:50 PM
  #26
xxxcowxboyxxx
i only play in the mud pits once in a great while. i dont do anything that involves intense articulation.
like he said with regearing......also i have NOT regeared.....nor do i plan to
Old Feb 21, 2010 | 11:59 PM
  #27
cowboytrucker32
crazy idea, could I cram 35"s under a 3" lift? or would I have to go with the coil spring idea, or a all out 5" lift?
Old Feb 22, 2010 | 12:02 AM
  #28
redheadhunter21
You will notice a decrease in power like I said earlier some learn to live with it and others feel its worth the money to regear as long as you dont drive it like a race car you wont start breaking drivetrain parts.
Lift it get the tires and then you can decide on gears
Old Feb 22, 2010 | 12:08 AM
  #29
cowboytrucker32
Sounds like a plan. I guess the regear will be the last thing ill do. It will happen sooner or later. But the 3" lift, could i do it? or would it have to be a 5"?
Old Feb 22, 2010 | 08:34 AM
  #30
xxxcowxboyxxx
with a 3 inch lift it "can" be done....however you may rub on for lock turns.
