46rh swap in a 46re truck ... one little problem
Old Mar 9, 2017 | 10:03 AM
  #41
Sketch1981's Avatar
Sketch1981
Default Swap a 46re in for a 46rh
My question is this
can you swap out a 46re for a 46rh wouldn't you just need to change the transmission control module and the wiring going to the transmission
thanks for your help
Old Mar 9, 2017 | 10:33 AM
  #42
There isn't a separate trans control module on these trucks. It is all in the PCM. You could possibly get a custom tune, that left out the governor stuff..... but, that would run 4-500 bucks.... Easier/better/probably cheaper to just get the right trans to begin with.
Old Mar 9, 2017 | 10:42 AM
  #43
Sketch1981's Avatar
Sketch1981
already have a trans thanks for the info about the pcm. Was thinking about putting a tune on it anyway's but a trans runs 600-1200 plus
Old Jul 10, 2017 | 10:39 AM
  #44
chuck1988's Avatar
chuck1988
What about taking the PCM and computer from the donor truck? I have a complete 97 ram, doing research on dropping the 97 318 and 46 RE into a 95 that has the 318 and 46RH. I would think that if you took the wiring harness, pcm and computer, it should work without any added labor than the harness and parts swap.
Old Jul 10, 2017 | 12:47 PM
  #45
Don't we have a thread going about just this swap?
It would be some work, but, certainly doable.
Old Jul 10, 2017 | 01:13 PM
  #46
chuck1988's Avatar
chuck1988
Guilty, I try to find as much info and get my info correct before I tackle a project like this solo.
Old Nov 11, 2017 | 12:25 PM
  #47
85 dodge D150's Avatar
85 dodge D150
what is the shift pattern of the 46rh??
is park all the way forward or back?
