EGR Code 32
Old May 25, 2010 | 06:55 PM
mjackson92rs's Avatar
mjackson92rs
Originally Posted by 95RAM360
i have the same code, but its not my egr valve, but actually the EGR pipe (cut it out)
when you did the plenum you have to of taken that pipe off...maybe its not tight enough back to the manifold...
and i get 14 mpgs city without the EGR pipe, so i doubt thats the cause of poor mpgs...it will contribute, but wont be the leading cause
The pipe and the valve are two different things. The pipe doesn't involve a valve that opens and closes. If the valve is stuck open, i essentially have a huge vacuum leak. If it stays shut when the truck thinks its open i have problems also.
Old May 25, 2010 | 08:16 PM
wjxavier's Avatar
wjxavier
i used to have and EGR code as well. when i was replacing my transmission, i also ended up replacing all my vacuum lines as well. it was cured and the light hasn't come on since.
Old May 25, 2010 | 09:07 PM
mjackson92rs
Well I just bit the bullet and put a new EGR on the truck. Will update in a week or so.
