Grille
Old Feb 21, 2010 | 10:42 PM
VEETEN's Avatar
VEETEN
Originally Posted by DukesOfHazzard
Sorry to jack, but how are the new aftermarket ones held in, double side sticky tape? or hardware?.. Or if you take them out to paint them how do you reinstall them, plastic epoxy? just curious if you ppl ever had problems after tearing them out
No need to remove inserts to paint the grille, I used what I had to cover them and sprayed..
Probably to hard to try and reattach them after anyway.Name:  0124001325.jpg
Old Feb 21, 2010 | 11:56 PM
dakotas ram's Avatar
dakotas ram
only reason i removed mine was to put in a billet grille.....
Old Feb 22, 2010 | 12:17 AM
Dixie Mudslinger's Avatar
Dixie Mudslinger
how do you put those on the shell? screws?
Old Feb 22, 2010 | 12:24 AM
dakotas ram
they make overlays that you keep the honeycomb and put over or the ones i had, you completely remove the honeycomb and it bolted to the grille bracket
Old Feb 22, 2010 | 12:26 AM
Dixie Mudslinger
ah ok i see saw them in LMC and wondered how they attached to the shell
Old Feb 22, 2010 | 12:29 AM
dakotas ram
not sure how the overlays attach tho
Old Feb 22, 2010 | 12:42 AM
Dixie Mudslinger
ah i was looking at replacing mine its the shell is broken away from the bracket and the chrome on the grille is peeling so i was wondering how hard it was to get the billet grilles to attach to the shell
Old Feb 22, 2010 | 12:59 AM
dakotas ram
on some aftermarket grilles, like my current one, the honeycomb is molded with the grille itslef and has to be cut out, chrome replacements should be the same as stock tho
Old Feb 22, 2010 | 02:28 AM
iwhitne's Avatar
iwhitne
Originally Posted by PurplDodge
I'm gonna miss him...The best damn moderator Dodge Forum ever had!
agreed... i missed a lot this weekend!
Old Mar 2, 2010 | 02:02 AM
tinkerinman's Avatar
tinkerinman
You can use a soldering gun and some abs cement to fix it. Then sand it and paint it...
