L.E.D. tail lights!!!!!!!
Old Feb 23, 2010 | 03:24 PM
tinkerinman's Avatar
tinkerinman
Lightbulb Anyone have a digram for under hood relays?
i need to locate my flasher relay. i just put on led tail lights and the signals do not flash!!! plz help!
Old Feb 23, 2010 | 03:42 PM
tinkerinman
Question L.E.D. tail lights!!!!!!!
Must you change the flasher relay to elctronic for signals to work correctly?????
Gerehead8's Avatar
Gerehead8
Need info on vehicle. What I think is happening is that the LEDs don't have enough electrical draw to get the flasher going. On my 1994 ram on the side of the dash (drivers side) there is a little door. Inside are fuse and the flasher (bottom little metal drum). Go to a parts store and get a flasher that handles LEDs.
I don't know if this is the same for all years though.
Welcome to DodgeForum
Old Feb 23, 2010 | 03:44 PM
Gerehead8's Avatar
Gerehead8
Yes. One thread is usually enough FYI.
Old Feb 23, 2010 | 03:45 PM
tinkerinman
thanks. thats what i figured....
Old Feb 23, 2010 | 05:44 PM
jasonw's Avatar
jasonw
Site Moderator
Not necessarily.
You can also wire in large resistors/ballasts that will make your lights work properly. Also, tinkerinman, you should create a signature that has some info on your truck, like model year, 4x4 or 4x2, 1500 or 2500, long box/reg box, reg cab/club/quad, engine, etc. etc.
Welcome to DF!
Old Feb 23, 2010 | 05:49 PM
MrRuckuss's Avatar
MrRuckuss
i didn't have to do anything to mine
Old Feb 23, 2010 | 05:57 PM
jasonw's Avatar
jasonw
Site Moderator
There, merged your two threads for ya, tinkerinman.
Old Feb 23, 2010 | 06:50 PM
Dodge4lyfe's Avatar
Dodge4lyfe
yes, LEDs do not have enough draw to work a mechanical flasher. They are dependant on load and LEDs don't draw enough current to make the flasher work. What you have to do is either get an electronic flasher or one that is designed for LEDs.(No-load flasher) This is what i had to do to get LED turn signals on my motorcycle to work...or you can buy a special crossover that wires between the 2 circuits, but thats a little more pricey.
