4x4 help plz
Old Feb 26, 2010 | 11:00 PM
yakkier's Avatar
yakkier
i got no idea on that one, but if i were you i would consider taking that front diff cover off and seeing if there are any teeth laying in it and see if everything is as it should be
Old Feb 26, 2010 | 11:02 PM
dustman3700's Avatar
dustman3700
will do thanks for all your help
Old Feb 26, 2010 | 11:04 PM
yakkier's Avatar
yakkier
Take some pictures if you can an post them, we love pictures also post your experience once you find out
Old Feb 26, 2010 | 11:06 PM
dustman3700
ok thanks again ill try to keep it posted on what i find from here out
Old Feb 26, 2010 | 11:14 PM
sk8erdude's Avatar
sk8erdude
i got a buddy with a cummins that had a problem with his 4 wheel drive kickin in, the disk that the fork pushes to lock in the 4x4 was a few thousands out of being round. he took it out and machined it down flat again, idk if that would be part of the problem.... at least thats how he explained it to me
Old Feb 27, 2010 | 10:30 AM
Sheriff420's Avatar
Sheriff420
Originally Posted by dustman3700
ok well ill start with checking the vac pressure i believe that is prob it because when i checked for the vac alternating between the tubes it was pretty weak any ideas what would cause this?
Did you put a vacuum gauge on it? It should be 20 psi at the CAD unit. I'm pretty sure you can get those as a loan a tool at the parts store.
Old Feb 27, 2010 | 10:58 AM
Gerehead8's Avatar
Gerehead8
Wouldn't that be 20 inches of mercury (in hg)? psi is pressure.
Old Feb 27, 2010 | 12:09 PM
Sheriff420's Avatar
Sheriff420
hmm... so that's why they put the " symbol instead of psi. whoops.
whatever, 20"
Old Feb 27, 2010 | 07:10 PM
dustman3700
checked the vacuum today wasnt that....ima leave school early monday and take it to the shop maybe they can find it ill let everyone know what they find
