idle problems
Old Feb 27, 2010 | 10:54 PM
davidkit's Avatar
davidkit
Default idle problems
i was just wondering if any one has a idea on my problem i have a 97 dodge ram 1/2 ton with 360 and when the truck is cold or after a 30 min. trip it idles real bad the exhaust smells like straight gasoline but if you tap the gas peddle it revs up for a min. and then goes away ive replaced the 02 before the cat. and the air idle valve and the intake gasket and the map sensor and plugs,wires,distributer cap and rotor,pcv valve,air filter,fuel pump,battery,and i have went threw all of the vac lines and still have not had any luck i was gonna replace the egr valve but the auto parts store told me my truck does not have one.
Old Feb 27, 2010 | 11:16 PM
tinkerinman's Avatar
tinkerinman
could be your voltage regulator.... Just did a bypass on mine because it is in the PCM... Check out the thread PCM???????????. Might be able to help you. GOOD LUCK
could be the TPS as well....
Old Feb 27, 2010 | 11:18 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You should check for codes first. And do a search here for Plenum.
Old Feb 27, 2010 | 11:21 PM
tinkerinman
Yes. Codes will help alot! If you do not have access to an OBDI use the trust mils method...
Old Feb 28, 2010 | 01:03 AM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
i was thinking plenum gasket myself.
Old Mar 30, 2010 | 12:00 AM
huttbutt's Avatar
huttbutt
What is the trust mills thing?
Old Mar 30, 2010 | 01:49 AM
tinkerinman
trusty mils method... turn key off and on three times leaving it on the third time...
the check engine light will blink in patterns of 2 numbers... for 1 will blink once. 2 will blink twice. and so on... Im sure you could find a list of mil codes on here somewhere if need be...
Old Mar 30, 2010 | 01:51 AM
tinkerinman
oh yea... and 5-5 signifies the end of the mil codes....
Old Mar 31, 2010 | 04:06 PM
zman17's Avatar
zman17
You are right, a list can be found. But one would have to take the time to search! https://dodgeforum.com/forum/2nd-gen...code-list.html
