So all I need is the pump, felpro timing cover gasket kit, bypass hose, pump inlet tube and timing gear/chain set for the front end right?
Quote:
You might want to change the T-stat while your there. If you haven't yet, grind or cut that stupid tab off the water neck base.Originally Posted by Sheriff420
You dont need a new pump inlet tube, unless yours is rusted apart or something, just clean it up and slap a new o-ring on. Other than that, I think you're set! RTV if ya dont have it.
Quote:
+ 1 on the RTV. I put RTV on the inside of the bypass hose, put the clamps on it, and let it sit over night before I put any coolant or water in it. You damn sure don't want it to leak after you get everything back together!!!Originally Posted by lblair04
http://www.durangoclub.com/forum/files/puller.jpg i needed one of these from autozone for the balancer, a regular three jaw one would just pull the balancer apart.Not sure about yours situation though
I went to get all of the gaskets this morning so I could go ahead and get the rear main seal done, but none of the parts stores had them. I did forget to check napa and carquest though, just realized that when I started typing.
Screw it, i'll order everything online.
Which RTV is the best to use? I tend to use the ultra black for most things. What applications would be it better to use the red, blue and ultra copper on instead of ultra black?
