Do I have all the parts covered?
Old Feb 28, 2010 | 10:19 AM
Sheriff420's Avatar
Sheriff420
Default Do I have all the parts covered?
I believe my timing cover is the source of my coolant leak and not that freeze plug after all.
Since I have to take the cover off I figure I may as well replace the water pump, the front main seal (I think that's what its called) and the timing chain/gears with double rollers.
Also since I'm going to be working on it anyway I figure I may as well replace the rear main seal and the oil pump.
So tell me if I'm missing anything.
http://shop.advanceautoparts.com/web...S_964152284___
http://shop.advanceautoparts.com/web..._1230006096___
http://shop.advanceautoparts.com/web...0_964157934___
Should I get this one or get the Mopar Performance set from Summit?
http://shop.advanceautoparts.com/web...0_729418481___
http://shop.advanceautoparts.com/web...S_964159196___
http://shop.advanceautoparts.com/web..._1016976785___
http://shop.advanceautoparts.com/web...A_965318090___
http://shop.advanceautoparts.com/web...S_581470654___
I also plan on throwing this in the front diff.
http://www.aussielocker.com/item.php...4/104001/.html
Old Feb 28, 2010 | 11:06 AM
halfamil's Avatar
halfamil
You'll need the repair sleeves for the harmonic balancer, and timing cover, new oil pick up screen, and oil pump shaft.That's all I can think of, now. I checked the engine and cooling system part prices on what you listed. Rockauto.com was $50 cheaper than Sadvance, including shipping, and that was with Cloyes high performance timing chain, and gear and a new Bocsh OE waterpump.
Old Feb 28, 2010 | 12:17 PM
Sheriff420's Avatar
Sheriff420
Alright, thanks.
Old Feb 28, 2010 | 12:18 PM
Ram_Me's Avatar
Ram_Me
Replace that annoying bypass hose to the waterpump too.
Old Feb 28, 2010 | 12:35 PM
dodgeram07's Avatar
dodgeram07
when i got my Felpro Timing Cover Gasket Set, it came with the front seal
and timming chain i when with a jp Performance
cant you just take the Pump Inlet Tube off the old one?
Old Feb 28, 2010 | 12:40 PM
Twisted Metal's Avatar
Twisted Metal
He probably could, but if his luck is anything like mine?(and I hope it isn't) That hose is gonna rip or crack. The hose is cheap, replace it.
Old Feb 28, 2010 | 12:45 PM
Ram_Me's Avatar
Ram_Me
Or he could have my luck and have the hose be stuck to the intake manifold. I tried everything to get it off. It's still there! Luckily, I was replacing it with a Hughes AirGap, so I let it be.
Old Feb 28, 2010 | 12:56 PM
lblair04's Avatar
lblair04
Sheriff, I got that same Fel-Pro kit that includes all the gaskets too. Your water pump will come with a gasket, but I opted to use the wp gasket from Fel-Pro. The other guy is right, the Fel-Pro kit does come with a front seal and also the repair sleeve (I did not have to use the sleeve). Also, make sure you have, or have access to a good harmonic balance puller, that goes inside the balancer, not on the outside. It took a few cominations of pullers from our auto hobby shop to find one that would work. I would also recommend the upper bypass hose. Also, it helped me to take the fan shroud off. This is just all from my experience, might be different for you.
Old Feb 28, 2010 | 01:10 PM
halfamil's Avatar
halfamil
When I did mine, the hose got messed up on the end, but it was still long enough to cut it off and fit it back on. The tube was a different story. I replaced the O-ring, and it leaked, tried it 2 or 3 more times, still leaked. A new tube came with the O-ring, it worked the first time.
Old Feb 28, 2010 | 01:17 PM
lblair04's Avatar
lblair04
As far as the o-ring, mine leaked too after I replaced the o-ring with one that fit on the end of the tube (took it to NAPA to find one.) But, when I put the new one on that came with the waterpump, it hasnt leaked. Make sure you put some coolant on the o-ring as lube before you put it in, so it doesnt tear the ring.
