transmission issues
Old Feb 28, 2010 | 03:44 PM
Kody's Avatar
Kody
Default transmission issues
Hi,
I have a 94 1500 that has some sort of tranny problem,
I was driving it and all of the sudden it stopped moving. The transmission had never slipped on me. It is not low on fluid. THe truck has 184k miles. I am not sure what went wrong but i would like to know. I am trying to sell the truck as is but i think if i just fix it it will be better.
It makes a slight wine when in drive and does nothing in reverse. neutral it does not do it either.
Once in awhile the truck will drive forward but only for a little bit. What do you guys think went wrong. Could it be the torque converter? Valve body? The pump?
Let me know if you have any ideas as i would like to fix this and get it sold cause i need the money.
Thank you,
Kody
Old Feb 28, 2010 | 03:47 PM
Gerehead8's Avatar
Gerehead8
Drop the pan and look for stuff in the bottom. Is the fluid still clean?
Old Feb 28, 2010 | 03:49 PM
Kody's Avatar
Kody
I have yet to do that, I plan to drop the transmission within the week but i would like to have an idea of what it might be.
The thing that bugs me is that it wasn't slipping at all.
the transmission on my 2500 did this same thing but it broke an Input shaft. also there was no whineing.
Old Feb 28, 2010 | 03:52 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
pull the stick and smell the fluid. these trucks are also known for their governor pressure sensor
when the trans took a sh*t in my truck it was great, no signs of a single thing wrong, ever, and then i came out to go somewhere an it wouldnt move.......damn dodges
Kody's Avatar
Kody
the fluid does not smell burnt,
I forgot to add that.
Old Feb 28, 2010 | 04:04 PM
95ram5.9's Avatar
95ram5.9
Only way to know what went wrong is to tear it down. Mine was whinning and eventually quite moving. Tore the tranny down and the one way clutch had grenaded. The clutch discs looked brand new. I think a lack of lubrication was the culprit. BTW, I don't think the 94-95 trucks have the governor pressure switch.
Old Feb 28, 2010 | 04:09 PM
95RAM360's Avatar
95RAM360
PO of my truckrebuilt tranny at 180K....said the torque convertor was shot, and the overdrive was gone...said it just dumped one day......hopefully this can give a slight idea since i have the 46rh as well.
Old Feb 28, 2010 | 04:27 PM
Gerehead8's Avatar
Gerehead8
Your right the 94-94 trucks use the 46RH which does not use a governor pressure switch. The one way clutch you are talking about is the overrunning clutch. The truck should still move in manual low (bottom position) and reverse even with a bad overrunning clutch. The low/reverse and should be holding in these situations. I bet the torque converter is bad or one of the seals blew out. When my TC went bad I would step on the thorttle truck would run up to maybe 2 grand then slam forward. I had a huge pile of s**t in my tranny pan thats why I suggested removing it. My fluid did not smell burnt and it not dirty either. Just like 95ram360 said mine just failed.
Old Feb 28, 2010 | 04:49 PM
halfamil's Avatar
halfamil
Mine did to, just out of the blue one morning.Right in front of the old N. Wilksboro Speedway. I got to see the last Nascar Winston Cup race they ran there.
Old Feb 28, 2010 | 04:57 PM
CPTAFW163's Avatar
CPTAFW163
I don't know of anyone that owns one of these dodges that doesn't have some type of tranny "issue" when it is over 70K.
