Accel plug wires, any good?
Old Mar 2, 2010 | 09:45 AM
halfamil's Avatar
halfamil
If it's running well, don't mess with it.
Old Mar 2, 2010 | 09:49 AM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
Originally Posted by Maxx_Magnum
its runnin good right now, other than the plenum issue. I just figured it must be time for a tuneup, I haven't chenged plug and wires in the little over a year I've had it and god knows when then last time they were changed. I gotta do the plenum sometime soon, so I figured I'd do it all, cap, rotor, plugs and wires. I'm strongly thinkin about doing the timing chain as well, I kinda think thats where I'm gettin some of the rattle noise. What's a loose t chain sound like anyway?
if your gonna rip as far in a t-chain you might as well spend the other 40$ and replace the water pump that will eventually sh*t the bed anyways. Should also think about putting in a 180 Tstat. just what i would do anyways.
Old Mar 2, 2010 | 09:53 AM
halfamil's Avatar
halfamil
A 180 t-stat won't work to good in Canada in the winter.
Old Mar 2, 2010 | 09:55 AM
halfamil's Avatar
halfamil
I'm going back to a stock t-stat, the first chance I get. If it's not sold first.
Old Mar 2, 2010 | 10:12 AM
xxxcowxboyxxx
yeha i didnt think about the fact he's in canada. halfmil....why you gonna switch back? iv never heard anything negative about them? i have a stock t-stat and was considering the 180 this summer but...........
Old Mar 2, 2010 | 10:47 AM
Maxx_Magnum's Avatar
Maxx_Magnum
ya I was gonna do the water pump too just so its done... my dad had to replace his last summer and the truck only had ~125K (kms) on it. I'm gonna start gathering parts here soon and do it all.
what difference does the 180 tstat make? Been wondering for a while. My temp gauge never moves once it's up to temp, and I've never saw it go above normal temperature. And the fact I'm in Canada seems to be a non issue, it's been warmer here than much of the US lately and I don't think we'll get much more cold weather now
Old Mar 2, 2010 | 10:52 AM
xxxcowxboyxxx
a 180 tstat will keep your coolant cooler than a 195 (15*), hence "performance"......i cant see is making a noticeable difference but everyone says it does so i was thinking about changing also
Old Mar 2, 2010 | 11:05 AM
halfamil's Avatar
halfamil
The heat is not good below freezing out, and around 10 degrees or lower, it throws a code.
The 180 helps if your engine pings with 87 octane.
Old Mar 2, 2010 | 11:16 AM
xxxcowxboyxxx
i must be the only one that runs 87 and havent heard a ping yet ?!?
Old Mar 2, 2010 | 11:23 AM
charlie1935's Avatar
charlie1935
There is at least two of us, cowboy.
