Misfiring
Old Mar 2, 2010 | 09:55 PM
titush1991's Avatar
titush1991
Default Misfiring
Hey guys im coming here for hopefully some help.
i own a 1996 dodge ram 1500 4x2 5.9L.
I was driving home from work when i started to hear a skipping sound from the engine. then the whole truck started to shake. i found out that it was missfireing and as soon as the RPMs would drop it would stall on me. the oil pressure was fine too.
so hoping it was just a cheap fix i did the spark plugs, distributer, and wires. after i replaced them the truck now will idle but still misfires. i did a compression test and the compression is down 30 in like 2 cylinders and cylinder 5 is at 0 compressions.
i also did plug in the computer and the codes are saying: misfires in cylinder 5, 7, and 8., multiple misfiring, and an idling problem.
it wouldnt just be a gasket would it? or the just the valves too?
any ideas?
thanks
Old Mar 2, 2010 | 09:59 PM
sit22 II's Avatar
sit22 II
You prob burned a valve
Old Mar 2, 2010 | 10:05 PM
Dixie Mudslinger's Avatar
Dixie Mudslinger
i agree thats what it sounds like. welcome to DF
Old Mar 2, 2010 | 10:38 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Your mileage may vary.
Old Mar 2, 2010 | 10:56 PM
yakkier's Avatar
yakkier
Rings and valves man
Old Mar 2, 2010 | 11:01 PM
master tech's Avatar
master tech
Site Moderator & Tech
Dodge has had problems with the valve seal cracking with high mileage, Above 70k. The fix is to replace both cylinder heads with reman's. But if you zero compression on one cylinder, you'll still need to remove the one head and ck the piston.
Old Mar 2, 2010 | 11:11 PM
yakkier's Avatar
yakkier
if i want to redo my heads, and i want to order some higher end ones IE from summit or jegs. i wont need to do anything other than just bolt them on right ?
Old Mar 3, 2010 | 05:23 PM
titush1991's Avatar
titush1991
ok thanks
any idea on how much it would cost for valves?
Old Jul 4, 2010 | 04:52 PM
palerider9999's Avatar
palerider9999
First make sure you did a compression check the right way. Throttle body at WOT with all spark plugs removed. I did a lot of research when I rebuilt my 1998. The stock heads are crap. They all crack. Just go to a salvage yard and try to find a good set. I did and gave up. If you have a cracked head(s) ,I found new ones on Ebay. They are a heavier casted head and decent price. I did have to lap the valves but they were very nice otherwise. I wouldn't go the extra money for a set of performance heads. They won't change the performance enough to justify the extra costs. Just my experience and .02 cents.
Oh, make sure you do a "permanent fix" on the plenum gasket if you get that deep in the motor.. It's prone to failing and will, sooner or later..
