Truck takes 6.5 Quarts?
Old 03-05-2010, 06:01 PM
blong4life's Avatar
blong4life
blong4life is offline
No aftermarket cooler, stock size oil filter, and this is at first fullup before I run it; my plenium is semi-fixed, but it dosn't dump right in there.
Old 03-05-2010, 06:18 PM
lblair04's Avatar
lblair04
lblair04 is offline
Could there be any possibility that your dipstick broke off, or someone stuck a different dipstick in? I dunno...my ideas might just be dumb since other people have had the same issue.
Old 03-05-2010, 06:43 PM
blong4life's Avatar
blong4life
Not sure, dipstick isn't broken off and it looks like the one from other dodges I've worked on it just seems weird.
Old 03-05-2010, 06:53 PM
DukesOfHazzard's Avatar
DukesOfHazzard
DukesOfHazzard is offline
Just keep in mind if your truck is on a incline, and let the oil settle after starting it up for a min ,
from experience, it will take over night for the level to be right, " BE PATIENCE" from oil change after oil change of experience. if you wa nt to be dead on. ^& otherwise
Old 03-05-2010, 07:07 PM
95RAM360's Avatar
95RAM360
95RAM360 is offline
+1 when i check my oil, i do it when the truck has been sitting overnight, and before i start it i check the oil...i check mine twice a week.
Old 03-05-2010, 07:10 PM
halfamil's Avatar
halfamil
halfamil is offline
I think he was kidding about the oil going in the plenum........5 1/2 qts. in my 95 360 with a larger than stock filter(Motorcraft FL-1A)
Old 03-05-2010, 07:21 PM
blong4life's Avatar
blong4life
Gonna start messing witht hat stuff next change, I was tight on cash so I did an advance special (Castrol Syntec Full Synthetic with a Bosch filter, $26.99 plus 2 additional quarts so like 40 bucks :/)
I do know there is a new pump/pan/gasket on there, so maybe there could be a bigger than normal pan? Dunno if they have them. Do need to work on getting larger Trans/Diff covers.
Old 03-05-2010, 07:40 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Dodge Forum Moderator
5.5 or more and mine shows a tad over the line on the stick. It drops a bit down after I run it and the filter gets completely full.
The PO of the truck had written with marker on the driver's side radiator support "6 quarts w/ filter". So I'm pretty sure he always overfilled it a tad.
Old 03-05-2010, 08:33 PM
codyselcamino's Avatar
codyselcamino
codyselcamino is offline
my 5.2 takes 6, I usually get the 5 quart jug and a lucus stabilizer, works out pretty good
Old 03-05-2010, 09:09 PM
DODGEPWR's Avatar
DODGEPWR
DODGEPWR is offline
Mine usually take 3.5 and goes down to 3.0 when i run it.
lol J/K Mine takes 5 quarts and its right at the full mark. I use a stock size filter.
Quick Reply: Truck takes 6.5 Quarts?
