Seized axle nut
Old Mar 6, 2010 | 04:45 PM
calgaryman's Avatar
calgaryman
Angry Seized axle nut
This weekend I decided to tackle balljoints, hubs, axle seals.
For the life of me I can't seem to get the axle nut off on the passenger side. I've let it soak in PB Blaster all night, I tried it with my impact, I tried it with my 4 foot breaker bar. Tried heating it up with a torch. I can't get this thing off!! I'm pretty sure it's not reverse thread but thought I would ask you guys. any other ideas?
If I can't get it off tonight (going to let it soak for a few more hours with the PB blaster) I might just toss the whole axle/hub and hit up the wrecker for a new axle.
TIA!!
Old Mar 6, 2010 | 04:49 PM
yakkier's Avatar
yakkier
Use a longer pipe, it will come off. PM 95RAM360 he'll tell you everything you need to know, he did it a few months back
Old Mar 6, 2010 | 05:02 PM
Sheriff420's Avatar
Sheriff420
How strong is that impact, foot pound wise?
Do you have any atf and acetone kicking around? Those two mixed 50/50 in a glass container (beer bottle) are supposed to be the best at penetrating rust.
Old Mar 6, 2010 | 05:25 PM
dhvaughan's Avatar
dhvaughan
you got a truck or tire shop nearby? drive it over there and have them break it loose with their big 1 inch mega-impact wrench. oil and reinstall it not so mega-tight and drive home to restart the job.
Old Mar 6, 2010 | 05:32 PM
Dixie Mudslinger's Avatar
Dixie Mudslinger
ye i did u-joints a while back and i ended up destroying mine getting it off had to go to the stealership and get a new nut what vaughan said is probably the easiest and least damage to the spindle nut
Old Mar 6, 2010 | 05:40 PM
calgaryman's Avatar
calgaryman
while I was waiting for the PB Blaster to "work" on the passenger side I ripped appart the drivers side. In hindsight this would have been the best option.
Not sure how many ft/lbs my impact is. i would imagine it's not the greatest, as it's just a small campbell hausfeld with the impact that came in the kit.
http://www.canadiantire.ca/AST/brows...Compressor.jsp
I will try the ATF/Acetone 50/50 mix. I will run to the auto parts store and pick up some acetone. there is no lack of empty beer bottles to mix it up in haha.
Thanks guys!!
DukesOfHazzard's Avatar
DukesOfHazzard
When i did mine this no joke, i had a 3/4 inch rachet with about a 6ft breaker bar and it took all three of us men to break that thing loose. Impact wasnt even budging it.
Old Mar 6, 2010 | 05:44 PM
Gerehead8's Avatar
Gerehead8
When I redid mine I slamed on it with a sledge hammer and used PB blast. Then I used an 600 ft-lb reverse imapact. It took about 2 hours a side with steady impacting to remove them. They were literally smoking as they came off.
Old Mar 6, 2010 | 05:46 PM
dhvaughan's Avatar
dhvaughan
a good nut will do that...
Old Mar 6, 2010 | 05:54 PM
halfamil's Avatar
halfamil
Put a 6-8 ft. or longer lenth of 2" ridgid pipe on your breaker bar and it'll come loose. Put it back at 175 ft. lbs. of torque if you can.Most likely the cotter pin will go in the same castle nut slot.
