Metal shavings in cooling system. Need to worry?
Old Mar 7, 2010 | 11:15 PM
cosmorphis's Avatar
cosmorphis
Default Metal shavings in cooling system. Need to worry?
To make a long story short, I snapped the back left bolt, holding the hose on top of the thermostat. I had to drill it out and re-tap it with a 3/8". In the course of doing so, I accidently drilled threw the bolt housing thingy (technical term) and got metal shavings down in there. I got most out with a magnet, but being the worry some wart I am, I would like to know if there is any cause for concern, because I know I didn't get them all out. The worst that I know of happening, is they end up in the radiator. What you guys say? Thanks!
Old Mar 8, 2010 | 12:09 AM
95RAM360's Avatar
95RAM360
i say flush the coolant system to be safe
Old Mar 8, 2010 | 12:12 AM
yakkier's Avatar
yakkier
you can do an engine flush to try an get them out, but as far as damaging anything it wouldnt hurt your engine, only thing it might do is make nicks inside your radiator hoses when it tracks back through that part of the system, and most likely will end up in the thermostat
Old Mar 8, 2010 | 12:14 AM
95RAM360's Avatar
95RAM360
could get caught up in the thermo and cause it to be stuck open/closed
Old Mar 8, 2010 | 12:18 AM
yakkier's Avatar
yakkier
Yup, that'd be the best spot to clean them out lol thermostat's are pretty cheap and easy to change
Old Mar 8, 2010 | 12:47 AM
cosmorphis's Avatar
cosmorphis
Sounds good. I won't worry about it at the moment. I've had a heck of time getting it back together. I broke the bolt off putting the hose thing back on, and then tried a bolt extractor and that broke off. I had to dremel out the broken bolt extractor with diamond tips, and then proceed to drill it out. It has a brand new thermostat on it at the moment, and so if anything goes awry, I'll check that first, and proceed to flush the system out. Word of advice--if the bolt doesn't go in smoothly, don't force it! Man, I learned that the hard way (but I'm sure most of you guys already know that).
Old Mar 11, 2010 | 06:36 AM
M.A.'s Avatar
M.A.
Radiator reservoir has a leak at the neck, I am planning on getting a new reservoir, What type of fluid do I need to use. I was told that the old type of green anti-freeze was not compatible with these motors, ram 1500 4.7? … Help
Old Mar 11, 2010 | 07:17 AM
dhvaughan's Avatar
dhvaughan
stay away from the RED DEX fluid for GM. its incompatible with GREEN.
Most of the antifreeze offered in parts stores is now a "universal" fluid. its costs about $1 per gallon more than the old green fluid. i just buy this stuff now.
Old Mar 11, 2010 | 08:09 AM
95RAM360's Avatar
95RAM360
I buy the Prestone for All Makes and Models..
