Why does my temp stay here
Old Mar 8, 2010 | 09:42 AM
BigDamYellowRam's Avatar
BigDamYellowRam
Default Why does my temp stay here
my temp gauge doesn't go any higher than this. Heater blows hot and its been 60 to 70 degrees. Just put in a 180 t stat it works fine. Would too much antifreeze make it do this or could it be a bad sensor?
http://i917.photobucket.com/albums/a...0307000947.jpg
Old Mar 8, 2010 | 10:01 AM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
well it looks like its sitting at about 170-175...... and you said you did just put in a 180 stat right? this could be a problem if it never reaches 180 only because at about 180 thats when your closed/open loop changes and you can run into some issues with codes being thrown such as somethign along the lines of "engine cold too long", i not sure of the exact wording. this said, the truck might not run the way you would think it should bc it never reaches operating temp and makes the open/closed loop switch
Old Mar 8, 2010 | 10:52 AM
Maxx_Magnum's Avatar
Maxx_Magnum
mine runs close to that, never moves once its there either
Old Mar 8, 2010 | 10:56 AM
xxxcowxboyxxx
mine runs just a shade higher, like the needle width higher
Old Mar 8, 2010 | 12:12 PM
BigDamYellowRam
I guess its fine, i just wasn't expecting that big of a difference on the needle, it would run hotter than that before I changed it even with the stat hung open. oh well hasn't thrown a code or anything that I know of.
Old Mar 8, 2010 | 12:31 PM
DukesOfHazzard's Avatar
DukesOfHazzard
Wow maxx have you had it up to 200 yet?, lol took a sec to remember them canadian gauges,
Old Mar 8, 2010 | 12:41 PM
Maxx_Magnum
HA I wish! these goddamned tires start shakin like a biatch at around 100. 120 is about the fastest I dare drive lol
I DID have an old 87 Camry, my first car when I was 18, up over 200 going downhill, with a DONUT TIRE on the rear no less. They rate them things for 80 km/h max, I dunno why? it held together alright, but talk about a funny noise comin from it at that speed but I was a teenager at the time, so I was invincible lol
Old Mar 8, 2010 | 02:45 PM
dhvaughan's Avatar
dhvaughan
my 180 stat runs just a smidgen higher, with the base of the red needle just touching on the 2. are you sure you put in a 180, or could it have been a 160.
if you've got heat, and no check engine light - i'd leave it be.
Old Mar 8, 2010 | 03:10 PM
DODGEPWR's Avatar
DODGEPWR
Mine runs at the same exact thing as the OP. I havent had a problem with it throwing any codes. No problems AT all.. So you should be fine.
I have a question tho. I guess the person that had my truck put in a cooler t stat? Is this what that means? Ever since i got my truck its ran in that exact same spot. Didnt know it, i thought it was running in the normal range that all rams ran.
Ive always been the kind of person to not want a cooler t stat. But i guess i have one? I guess it'll help out here in FL tho... Or should i put in a stock one?
Old Mar 8, 2010 | 05:07 PM
Twisted Metal's Avatar
Twisted Metal
Mine is in the same position as the OP's. I run a 180 stat, I get an occasional p1281 code for engine cold too long.
PWR, more than likely is was swapped to a 180, the 195 stats bump the needle up a little more. MHO, if it ain't broke don't fix it. Its not goning to hurt anything with a lower stat.
