Dash fix opinions?
Old Mar 10, 2010 | 05:45 PM
PurplDodge's Avatar
PurplDodge
Originally Posted by Scottmilkeway
@mr freeze: ohhh gotcha yeah i think no matter what its still not gonna convince me or my dad to buy it
@Purpldodge: im not lookin to replace it im lookin to repair it, mines to too severe, i just wanna prevent future holes
You cant prevent future holes once it starts to crack.
Black Duct tape is your friend.
Old Mar 10, 2010 | 05:50 PM
Scottmilkeway's Avatar
Scottmilkeway
lol yeah i thought about that , but what im sayin though is the stuff im looking at is rubberized which im thinking if sprayed on the epoxied cracks, would first make it look cosmetically good, and second it would hold it together... maybe ill use some herculiner on it when i herculine the bottom half of my truck this spring
Old Mar 10, 2010 | 05:54 PM
mr freeze's Avatar
mr freeze
There is always the carpet covers which cost about 40 bucks or so.Then there are the covers which can be had for about 130 bucks if you look around.
Old Mar 10, 2010 | 06:12 PM
PurplDodge's Avatar
PurplDodge
I doubt that any coating will prevent the dash from cracking. Probably make it crack some more over the weight of the coating.
Old Mar 10, 2010 | 08:15 PM
Scottmilkeway
i would think its pretty light stuff
Old Mar 10, 2010 | 08:16 PM
dustman3700's Avatar
dustman3700
i have the same problem....im 16 too...like u i was thinking in class and i had the idea of taking the entire dash out getting some thin sheet metal and cut the sheet metal to fit on the bottom side of the dash while using liquid nail or some equivilent to attach the metal to the dash then taking body filler to fill in the cracks on top then sand the dash itself and use a high quality plastic paint kit to repaint the dash to match
Old Mar 10, 2010 | 08:31 PM
DODGEPWR's Avatar
DODGEPWR
Well, after buying all that and finishing with your high quaility paint...You'd probly be able to buy this.
http://cgi.ebay.com/ebaymotors/94-95...item2305408695
And there would be alot less work involved..
Old Mar 10, 2010 | 08:47 PM
Scottmilkeway
haha two great minds think alike yeah i had also thought about molding metal or even wood lmao, but there just seemed like too much work involved
jasonw's Avatar
jasonw
Site Moderator
Don't take this the wrong way, but this happens a lot. A new guy, such as yourself, comes in and thinks he's got the answer to an age old problem, an answer that no one else has ever thought of. The problem is, this has been thought of before.
I remember someone attempting this exact same solution a while back. The problem is, once the dash starts to crack and develop holes, you can't remove it to put sheet metal down and then reinstall it. When you go to remove it, it will crumble like stale bread. If its that far gone, it will not come out in one solid piece. I've heard enough stories on here to know this.
So unless you want to put the sheet metal (or whatever) down and then glue the dash onto it like a crumbling bunch of puzzle pieces...
Save up the cash if you don't have it, and get a new dash. And not one from a stealership either. Get a good aftermarket unit that won't pull this crap on you again. Do it right the first time and never worry about it again.
Old Mar 10, 2010 | 09:07 PM
Scottmilkeway
mines not too far gone since its the last year they made the 2nd gen, the hole was cuz i pounded on it out of rage, like its not so far gone i could go ahead and pull a piece off like bread, but i do know what your sayin
