PurplDodge's Spring Project
Old Mar 19, 2010 | 04:14 PM
  #21
Maxx_Magnum's Avatar
Maxx_Magnum
good job purp! can't wait to see this project come together! I'll be doin the same thing here sometime soon, maybe minus the HSRR's...
Old Mar 19, 2010 | 04:39 PM
  #22
95RAM360's Avatar
95RAM360
Map gas is the best to get out bolts....hasnt failed me yet....
Old Mar 20, 2010 | 12:53 AM
  #23
2001Ram's Avatar
2001Ram
Your not old enough to order ****. Duh.
Cant wait for the DIY.
Old Mar 20, 2010 | 10:08 AM
  #24
Trey318's Avatar
Trey318
Its good to see you getting to do some work over spring break. I missed a third of mine in the hospital with appendicitis. Now no lifting over 10lbs or strenuous activity for 6-8 weeks
I'm glad you're replacing that 3 dollar bypass hose with a Gates. I used some normal hose with the right ID, but apparently it wasn't flexible enough. It kinked over time and cracked in the middle of an intersection between two major highways in my part of town. Luckily my buddies were following me and helped me push the beast out of the turning lane when it overheated and died. I learned my lesson.
Old Mar 20, 2010 | 12:06 PM
  #25
gipperkid's Avatar
gipperkid
What is the part number for HS 1.7s?
Old Mar 20, 2010 | 03:36 PM
  #26
mr freeze's Avatar
mr freeze
These are the non adjustable 1.7 roller rockers.
http://www.summitracing.com/parts/CSP-S70037/
Old Mar 21, 2010 | 12:26 AM
  #27
iwhitne's Avatar
iwhitne
look forward to seeing the end result purpl... I'm going to have to do mine soon... maybe this fall
Old Mar 21, 2010 | 07:06 PM
  #28
PurplDodge's Avatar
PurplDodge
S70037. Order from John at Southeast R/T.
BTW he sent me a present on Friday....
I also got the manifold and throttle body clean. And the new spark plugs and O2 sensor in. DIY will come for that, too. I start on the timing chain tommorow, I need to get a harmonic balancer puller and installer from my uncle
Ohhhh, that really sucks! Hope you get better soon!
The Gates hose was $8. How could you go wrong with that!
Old Mar 21, 2010 | 08:20 PM
  #29
PurplDodge's Avatar
PurplDodge
Originally Posted by BIGRED97
e
i broke a bolt when doing my buddies, if you ahve a torch to something and apply some heat to it it should come right out with vice grips otherwise it is a real PITA! we tried for two days with pb blaster and vice grips, applied some heat and came out in 5 min.
Will do! Thanks!
Here are some pics of my new Harland Sharps. I've got them soaking in Mobil 1 High Mileage right now.
And I saw this ugly thing Saturday night while watching Forensic Files
Old Mar 21, 2010 | 09:09 PM
  #30
gipperkid's Avatar
gipperkid
Why does Summit have two different options? Other than price, not sure waht the difference is.
