PurplDodge's Spring Project
Old Apr 4, 2010 | 07:46 PM
  #81
PurplDodge's Avatar
PurplDodge
Originally Posted by aim4squirrels
I agree with Vaughan, you've got an S-load of sludge there, Purp. That probably means you have a bunch of coking in the lifter gallery under the spider retainer, too. You shouldn't have that type of build up on the pushrods and heads. Looks like dino oil was run in it for the better part of it's younger life and a lot of short trips where the engine barely got hot and shut down. That's just a guess, of course.
You need to be very careful trying to clean that out all in one sitting. I would do several filter changes at 1000 mile intervals after the initial flushing. If too much of that gets loose all at once, you could plug the filter up, and then an oiling hole or two.
I wish I would have seen this thread about 2 weeks ago, I'd have told you to hold off on the Cloyes chain or at least run a tensioner with it. My Cloyes HD chain only got about 30,000 on it before it was loose again. The distance of the camshaft to crankshaft creates a geometry that make stroking these motors very friendly compared to others, but the timing chain is much longer because of it. They need the extra help of a tensioner, or a really heavy duty one like the JP Performance or Rollmaster types. Those cost considerably more, of course.
Anyway, just enjoy it for now and in 30K if it just doesn't feel as peppy on the gas, consider the chain.
Make sure on the flush stage that you get the engine up to operating temp for an extended period of time to get that crap to really liquefy and down into the filter. I've also heard of this stuff called Auto RX that supposedly does the cleaning job slowly, as to not cause major mechanical issues. I can't comment on the job it does as I don't really have that much crud in there to clean, but I have run it and there were no ill side effects.
Now, I wish you would have told me this about 3 weeks ago. Them damn squirrels, I tell 'ya!
Old Apr 4, 2010 | 09:34 PM
  #82
aim4squirrels's Avatar
aim4squirrels
Like I said, don't sweat it unless you notice a bit of a loss revving up.
Old Apr 4, 2010 | 11:17 PM
  #83
PurplDodge's Avatar
PurplDodge
Timing chain was easy anyway. If I feel the need that it needs replacing, I'll replace it (With a JP).
