PurplDodge's Spring Project
Old Mar 26, 2010 | 12:18 AM
  #61
95RAM360's Avatar
95RAM360
She sounds good....so it was just the plenum and the 1.7s that you did right? any you noticed that much differnce.....i noticed a good difference after the plenum fix, but now i want to try some 1.7's
Old Mar 26, 2010 | 12:22 AM
  #62
PurplDodge's Avatar
PurplDodge
I did the plenum, 1.7s, timing chain, water pump, spark plugs, and oxygen sensor. So I'm seeing gains from all of that. Pretty much a brand new engine with 180,000 miles? As you can see, my timing chain had lots of slack in it!
http://www.youtube.com/watch?v=7vjkPZ0r4ZQ
This weekend I might Seafoam it.
Old Mar 26, 2010 | 12:26 AM
  #63
95RAM360's Avatar
95RAM360
HOLY ****....first up on my list Timing chain....dont know if it has been done before....minor minor slack (hardly any) when i did timing cover gasket 4 months ago....i got 201K
Old Mar 26, 2010 | 12:27 AM
  #64
PurplDodge's Avatar
PurplDodge
It was $37 for a new U.S.A. made Cloyes. Replace it.
Old Mar 26, 2010 | 12:31 AM
  #65
95RAM360's Avatar
95RAM360
i did the timing chain on my 93 Nissan 4x4 by myself...so i think i can handle the timing on this...i got to get a timing light...now i heard that this truck is TDC at #6 cylinder compression stroke....this is wrong right....its the #1 cylinder compression stroke...(havent looked at write up yet)
Old Mar 26, 2010 | 12:38 AM
  #66
PurplDodge's Avatar
PurplDodge
I didnt even bother with that. Just line up the two little dots and go.
I believe it is #6 TDC.
I need to do the timing chain on the S-10 next (Why I asked!). I suppose that will be harder because there is so much less room to work in. In the Dodge, I can take off the fan shroud and sit on the radiator. Its kinda comfortable because you are arm's level with the motor. Its easy, I knocked mine out in 2 hours.
Old Mar 26, 2010 | 12:42 AM
  #67
95RAM360's Avatar
95RAM360
i was thinking when i take the chain off theres two darker links that line up to a dot on the gears. The gears are on key weights, so they go in one way, so is it just a simple swap without having to do TCD?
ligned up as it was before obviously
Old Mar 26, 2010 | 12:49 AM
  #68
PurplDodge's Avatar
PurplDodge
Yes.
BTW it is sleeting here in Indiana, in March. I was gonna mow tommorow!
Old Mar 26, 2010 | 12:52 AM
  #69
95RAM360's Avatar
95RAM360
My mom said it was snowin like a b!tch in Maine the other day, when she said the day before was in the 50-60's
and cool....i have 1 day off a week now, im busy like 24/7 now lol...maybe a week from this wednesday ill do it.
Old Mar 26, 2010 | 12:58 AM
  #70
PurplDodge's Avatar
PurplDodge
****, now it is snowing.....So I gotta take the mower deck BACK off the tractor and put the blade back on!
Just kidding, I dont have a tractor!
