York 210 OBA Install
Old Mar 21, 2010 | 09:13 PM
EricCartman's Avatar
EricCartman
Talking York 210 OBA Install
I decided that I wanted OBA for my truck. After some research, I decided that I wanted to go with a York 210 compressor. The only problem was that there was not any readily available brackets to mount this onto my engine. After some searching, I found a website (TXWheelers) that drawings of brackets! Link: http://www.txwheelers.com/modules.ph...g2_itemId=9709.
The pictures below are from my build using the above plans. I made some minor modifications, but the ideas came from the TXWheelers page.
I made some ghetto-fabulous circle jigs for my plasma cutter… Thirty cents in miscellaneous parts seemed a whole heck of a lot cheaper than the $100 tool that Miller was selling.. I drilled and tap the steel plate so that I could attach the jig, allow it to move and not have it walk all over the place.
Here is what it looked like once I got all of the blanks cut out. I was able to get all of this out of that one piece of steel shown above.
I had to make another ghetto fabulous jig for drilling the adjustment slots. I didn’t trust myself to try that with the plasma cutter… but the drill and air file seemed to be a good combo.
I had to tack weld it all together to make sure the pulleys and stuff were lined up correctly. It looks like it might be a little off in the photo, but it lines up perfectly on the back groove of the compressor.
Here it is finished welded, and half installed into the truck:
Now, with the York mounted up:
Coalescing filter and check valve, mounted on passenger side fender well:
Air manifold:
This continues on to a 3 gallon air tank mounted on the frame rail (in front of the gas tank).
This is probably one of the better modifications I have made to my truck. It is really nice to have a shop grade air compressor bolted into my truck. The compressor can keep up with just about any air tool I would ever need to use.
[EDITED TO ADD NEW PICTURES]
Some toys to use the OBA... Horns, mounted on the outside of the driver side frame rail:
And here is a shot of the air tank. It is mounted on the inside of the driver side frame rail:
Cartman
Last edited by EricCartman; May 3, 2010 at 11:36 AM. Reason: Added air horn & tank pictures
Old Mar 21, 2010 | 09:29 PM
BIGRED97's Avatar
BIGRED97
now its time for a train horn!
thats a really sweet mod, i like it alot! great writeup
have you noticed any loss of power or anything of that nature with it on?
Old Mar 21, 2010 | 10:11 PM
pcfixerpro's Avatar
pcfixerpro
So were gonna fab one up for mine next weekend right? Haha, very nice job!
Old Mar 21, 2010 | 10:42 PM
PurplDodge's Avatar
PurplDodge
Great job!!! This is much a much better idea than buying a shop compressor for my garage!
Old Mar 21, 2010 | 10:54 PM
iwhitne's Avatar
iwhitne
Hiw much to make me the same set-up?... NO JOKE I want one!
Old Mar 21, 2010 | 11:13 PM
dakotas ram's Avatar
dakotas ram
nice work man!!! hows your truck idle while using it?
Old Mar 22, 2010 | 12:14 PM
EricCartman
Thanks for the comments.
I've got some train horns... just didn't get around to taking pictures of them yet. I went with the Shocker XL from HornBlasters. I'm pretty happy with them. They are plenty loud. They seem to have a deeper tone than a typical train horn - which is fine by me. They definitely get people's attention. Even people that knew it was coming, jumped when I honked them.
I haven't noticed any problems at idle. I'm sure it adds some drag, but not enough that I notice it. It starts/idles fine, even if I have AC/Defrost and the air compressor on at the same time. I have not really noticed a loss of power while driving either.
At idle, it will charge the system from 0psi to 150psi in about 40 seconds (at idle). If I'm driving down the road at about 2000 RPMs, it will fill in about 25 seconds.
The next thing I am planning on doing is adding a hand throttle so I can raise the RPM of the engine if I'm not in the truck. I've seen a couple of write-ups on doing this... just need to carve out some time to do it.
It's definitely worth doing if you ever need air. It was relatively cheap to do. I was able to do it for just a little more than it would have cost to get a decent Viair compressor and the rest of goods to go along with it. It could be done even cheaper if you wanted to eliminate the coalescing filter, but I didn't want to deal with having oil in my air lines that could find it's way into my tires.
The major components:
York 210 from junkyard: $25
1/4" plate steel: $13
Alternator Pulley (Kilby Enterprise): $65
1/2" NTP adapters for compressor (Kilby): $45
Coalescing Filter: $45 <-- same one Kilby sells for $115
V-belt: $10
Check Valve: $18
Then you have to add the cost of whatever hose, fittings, manifolds, etc you want to use (but you would have to buy these anyways if you were going to use an electric compressor too).
This can be done without hose adapters for the compressor, but it makes it easier to hook up hose in the end- so I decided to purchase them.
My motivation was that I plan on towing some things this summer, and I wanted to add some helper air bags. The trains horns are for entertainment. Now I just need to find an impact gun to keep in my toolbox. Maybe an air over hydraulic jack too.
Thanks,
Cartman
Old May 2, 2010 | 12:23 PM
Dont suppose we could talk you into marketing the brackets could we?
This is an extremely worthwhile mod, excellent job.
Old May 2, 2010 | 12:37 PM
Maxx_Magnum's Avatar
Maxx_Magnum
ya I believe a lot of work went into this mod... I remember this thread when he did it.... props to ya Cartman!
Old May 2, 2010 | 12:38 PM
lord0fsal3m's Avatar
lord0fsal3m
that thing is awesome, i have no need for air, but thats just cool to look at lol. great work
