Help me!!!!!!
Old Mar 23, 2010 | 05:54 PM
  #21
blong4life's Avatar
blong4life
Originally Posted by Gerehead8
1995 DODGE trucks were OBD I. In 1996 they were OBD II. Some other vehicles where OBD II a few years earlier like camaros, but dodge trucks were not. The OBD I trucks do have a diagnostic port on them under the hood and maybe under the dash. The codes can be read by a reader but usually only shops have the tools to do this. Not really a big deal because you can do the key dance (search) to read the codes.
Correct; we got the 7-pin connector under the hood (right above the PCM)
Old Mar 23, 2010 | 08:05 PM
  #22
Gantryman's Avatar
Gantryman
to get the codes simply turn the key from 'off' to 'on' 3 times quickly then to on. the check engine light should flash once then twice quickly. write down all flashes after that. when the pcm is finished give code it will flash 5 times quickly twice
Old Mar 24, 2010 | 01:04 AM
  #23
xray99's Avatar
xray99
I have a 95 Lesabre, it has a port under the dash that hooks up to my OBD2 reader, it'll go through the motions of detecting protocol and whatnot, but in the end comes up with a reading error.
Old Mar 24, 2010 | 01:16 AM
  #24
yakkier's Avatar
yakkier
Bad cat.
