Freeze plugs...please clarify
Old 03-30-2010, 04:26 AM
lblair04's Avatar
lblair04
lblair04 is offline
Default Freeze plugs...please clarify
Hey all,
Can someone please tell me what size of freeze plugs I need for the rear of the block (between tranny).
Thanks
Old 03-30-2010, 06:43 AM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
Old 03-30-2010, 12:56 PM
J415's Avatar
J415
J415 is offline
You need a shallow 1 5/8 inch BRASS plug. They cost about $4 a piece.
Old 03-30-2010, 01:16 PM
dkishton1486's Avatar
dkishton1486
dkishton1486 is offline
1 is 1 5/8 and the other is 1 1/4.. are you sure its the rear ones leaking and not the one by the oil filter?
Old 03-30-2010, 02:04 PM
gobbell1's Avatar
gobbell1
gobbell1 is offline
I did mine last year and they are 2 different sizes. I can't remember the size, but I removed mine, then mic'ed it and found a match at Advance. It needs to be a tight fit!
Old 03-30-2010, 06:38 PM
lblair04's Avatar
lblair04
lblair04 is offline
Im pretty sure its the rear ones. Im putting it up on a lift on Friday to check it out more and fix whatever it is. Its dripping off of the bell housing. Also going to check the rear of my intake manifold, since I just did my plenum and noticed it after that. I smelled antifreze before the plenum tho, so thats why I assume its a freeze plug.
Either way, I will definately check it out real well before I pull the tranny for it to turn out to be an accessible one.
Old 03-30-2010, 09:06 PM
J415's Avatar
J415
J415 is offline
I hate to disagree, but I just did mine last week and they're 1 5/8. He's talking about the ones between the tranny and engine. Those are BOTH 1 5/8. He's not talking about the one's behind the heads. I know those are smaller.
Old 03-31-2010, 09:10 AM
gobbell1's Avatar
gobbell1
gobbell1 is offline
Perhaps we have different engines. My block freeze plugs were definitely different sizes. See pics
http://bellsouthpwp2.net/t/h/thegobb...ze%20plugs.jpg
Old 03-31-2010, 11:33 AM
J415's Avatar
J415
J415 is offline
Yeah, we do. I have a 5.2 block. So I guess we just figured out that the 5.2 block takes two 1 5/8 plugs and the 5.9 block takes one 1 5/8 plug and one 1 1/4 plug. Sounds good. This should be in the FAQ page.
On a a side note, thanks for your tranny rebuild notes gobbell1. I'm in the process of rebuilding my tranny and your pics and note are very helpful. I just hope that my completed tranny comes with the same success you had with yours.
Old 03-31-2010, 11:39 AM
gobbell1's Avatar
gobbell1
gobbell1 is offline
J415...you are most welcome on the pics/manual. I noticed that some of the pics aren't as clear as they need to be. So, if you have any questions, please let me know.
15k miles on rebuild and counting!!!!
Quick Reply: Freeze plugs...please clarify
