Freeze plugs...please clarify
Old 04-03-2010, 01:39 AM
lblair04's Avatar
lblair04
lblair04 is offline
Thanks for all of the replies! I learned a lot! BUT, I have GREAT news!! I crawled under it to inspect it better and its not the rear freeze plugs...its my block heater leaking!!!! Made me so happy! Im just going to take the heater out since Im going to New Mexico next, and replace it with a brass one.
THANKS!!
  #22
Old 04-03-2010, 10:27 AM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
What's wrong with a putty knife and some RTV?
JK
  #23
Old 04-03-2010, 10:32 AM
Augiedoggy's Avatar
Augiedoggy
Augiedoggy is offline
Originally Posted by Hahns5.2
I feel your pain, I also have a freeze plug on the back of the block that's leaking, I've been way too busy to mess with it so I just dumped a tube of stop leak in it for now, it's actually working great so far.
ditto....but mine started leaking again...
  #24
Old 04-03-2010, 01:32 PM
lblair04's Avatar
lblair04
lblair04 is offline
Peace of mind...I wanna know its done right...all my tools are packed up and on their way to New Mexico, so this is the last time I will have acess to tools to do it. Plus, its cheap and I have a $10 off coupon for the auto hobby shop on base!
  #25
Old 04-04-2010, 01:23 PM
lblair04's Avatar
lblair04
lblair04 is offline
Replaced the block heater with a brass freeze plug. No leaking. Thanks a lot for all the replies!
Started gathering parts for the check ball delete, but cant come up with one adapter and im $50 into it. Pissed me off. Im just going to take the old hose to a shop and have them build me a hose without the check ball. They told me it would be around $50 and its not a pieced together part...
  #26
Old 04-04-2010, 05:40 PM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
You know you could just double clamp a piece of transmission line onto the metal lines and the fitting on the radiator.
  #27
Old 04-04-2010, 09:27 PM
lblair04's Avatar
lblair04
lblair04 is offline
Have you had any problems doing it that way? I wouldnt think it would hold without the hose barb... Learn something new everyday
  #28
Old 04-04-2010, 10:51 PM
Sheriff420's Avatar
Sheriff420
That is how mine is connected and it works fine. Just use two hose clamps on each end and get them tight.
How much pressure are those lines subjected to anyway?
  #29
Old 04-05-2010, 02:00 AM
lblair04's Avatar
lblair04
lblair04 is offline
Im not sure how much pressure...but I know in one of the write ups, the guy said to make sure the tranny line is rated to AT LEAST 150 psi. The tranny line also has steel mesh in it I believe to keep it from bursting.
  #30
Old 04-05-2010, 07:14 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
there's not a lot of pressure, but there is a lot of heat. the transmission hose has fiber weave embedded, same as fuel line hose. no steel mesh that i've seen.
of my 4 non-barbed hose connections, the 3 with double clamps have never moved. i did have one pop off that only had a single clamp on it and it was a crappy clamp that didn't fit right. it was my own dumb fault.
Quick Reply: Freeze plugs...please clarify
