Road trip emergency
Old Mar 31, 2010 | 01:06 AM
dhvaughan's Avatar
dhvaughan
deleted.
Old Mar 31, 2010 | 01:07 AM
CPTAFW163's Avatar
CPTAFW163
The best option is to have it towed to a junkyard with a dodge ram with the same engine. I was quoted once for 750 for a new engine swap. That is your best bet, and the cheapest.
also, do not try to get a 5.9 engine in there. the PCM (computer) will be completely different.
GOOD NEWS:
Many 1996 5.2s are junked because of blown transmissions. So the engines are really good. I had 3 different trucks for me to choose from in Lawton OK.
Steps:
1. look up a junkyard in amarillo.
2. Call them and tell them you need an engine swap for your vehicle.
3. They will probably have one. if not, they will call around to get one.
4. They will warranty the part, but you can only bring it to THEM to get it fixed.
-Dan
Old Mar 31, 2010 | 01:08 AM
CPTAFW163's Avatar
CPTAFW163
GOOD NEWS:
Steps:
-Dan
__________________
Old Mar 31, 2010 | 01:13 AM
jasonw's Avatar
jasonw
Site Moderator
Both threads merged together. No need to create two separate ones.
Old Mar 31, 2010 | 01:20 AM
CPTAFW163's Avatar
CPTAFW163
Oh,
You are in luck with that engine. Because 5.2L magnum engines are in same year Jeep Grand Cherokees and Dodge Durangos. ALL you need is a 5.2L magnum engine. So any junkyard in amarillo will have them.
www.car-part.com
I did a search, and no junkyards were in amarillo (or at least none that list their entire inventory online).
Try calling some of these guys:
http://www.superpages.com/yellowpage...TX/T-Amarillo/
Old Mar 31, 2010 | 03:21 AM
Skyy's Avatar
Skyy
If you are thinking of getting it transported home there is a website I have used to have stuff hauled called uship its a reverse ebay for shipping
post on there you need the truck transported ASAP and see what someone will charge you just an idea
I have had great luck with it
Had my Chevy truck shipped from Ohio to WI for $200
Old Mar 31, 2010 | 08:53 AM
aim4squirrels's Avatar
aim4squirrels
I wish I could help, I don't know a good shop in Amarillo. Might scout the yellow pages and call around. Look for places that do more than "Lube & Tune."
I agree with Vaughan, head gasket is the most likely culprit with the symptoms you described.
A faint ring of coolant on the top of the oil dipstick, milky colored oil, or a sweet smell in the exhaust fumes are the tell tale signs.
Old Mar 31, 2010 | 09:23 AM
95RAM360's Avatar
95RAM360
head gasket or cracked head like dhvaughan said.
And def. check if the oil looks milky, thats the ost obvious sign of a bad head gasket or head.....Also the intake gaskets could be leaking in the back driver corner. Theres a coolant race there.
Old Mar 31, 2010 | 10:00 AM
msteel's Avatar
msteel
I appreciate all the advice.
Suspect the fuel pump may not have been the original problem, although the garage said they would check codes and pressure test. Don't know if they did.
Transmission rebuilt and still strong.
Checking for junk yards and shops in Amarillo this am.
Also will get a quote from uship and rental car. Looks like the best option.
Last resort I'll drive up and dolly it back.
Great forum.
Tom
Old Mar 31, 2010 | 05:19 PM
xray99's Avatar
xray99
glad you aren't giving up on her [the truck] just yet, keep us updated with any new info.
