MonteC's Transmission Corner (For Info Only)
Old Apr 13, 2010 | 10:16 PM
  #91
ghost4321's Avatar
ghost4321
Originally Posted by MonteC
Wow thats cold. I would get a temperature gun and verify what your gauge is reading. If you are infact running that cold on the hot side, i would clean out or replace the radiator and run the cooler lines back through the rad to warm that fluid up.
Will do, thanks.
Old Apr 13, 2010 | 10:30 PM
  #92
BlueBeast2's Avatar
BlueBeast2
Some will. As long as you are under 230 you are good.
I think I was damn close to that the other day. Will a 2300 tc make a difference in how hot it gets?
Old Apr 13, 2010 | 10:32 PM
  #93
MonteC's Avatar
MonteC
a torque converter has everything to do with how hot it gets. A low stall converter will not produce the same amount of heat a higher stall converter does.
Old Apr 13, 2010 | 10:35 PM
  #94
BlueBeast2's Avatar
BlueBeast2
So there's my answer on why I run hotter then 99% of the people on here lol. I feel better now.
Old Apr 14, 2010 | 04:25 PM
  #95
ghost4321's Avatar
ghost4321
Well I did some testing today and found out one of two things. Either the laws of physics no longer apply, water boils at 160F and we're all going to die as the universe flies apart at the seams or my freebie gauge reads about 60F low.
Old Apr 14, 2010 | 06:19 PM
  #96
MonteC's Avatar
MonteC
lol!!
Old Apr 14, 2010 | 08:11 PM
  #97
xjarhead69's Avatar
xjarhead69
Service manual thats in the 2nd Gen Faqs Diy for download will tell you.
Starting on Page 8w-80.
Good luck.
Dave
Old Apr 14, 2010 | 08:18 PM
  #98
xjarhead69's Avatar
xjarhead69
Just got thru watching the ATSG video on the A500 how much difference is there between that and 46re? Do they have a video and service manual that actually covers the 46re? Everything I have seems to cover the Rh only.
Thanks
Dave
Old Apr 14, 2010 | 08:19 PM
  #99
MonteC's Avatar
MonteC
Originally Posted by KYHI
I have a 98 dodge ram with a 46RE trans..
Ran fine one night and was real slow on takeoff the next morning..
Autozone pulled a PO753 Code (seems to have gone bad overnight) - I replaced the govener pressure solenoid as they stated - but did not fix the problem
Still getting the same code - seems to be starting out in a high gear (seems like no first or OD) - spoke to tech support at transgo and he stated it is a relay problem
I downloaded a trans troubleshooting pdf..
I swapped the trans relay several times and that is not it...
the pdf shows the 8 pin trans solenoid connector pin layout and have read that you need to use the dodge scan tool to run some of the tests...
Is there a way to test the connector wires for input and output voltages?? and a diagram to and from the 8 pin connecter to other end (to test for open or shorted wire)???
PS - I test drove the truck with the solenoid connector unplugged and there is no difference with or without it connected...
You have a bad 3-4 shift solenoid. The two that are held onto the valvebody with 3 screws. One of those has gone bad, you have to replace the whole set which involves removing the valvebody.
  #100
xjarhead69's Avatar
xjarhead69
Default Trans Overhaul Video
Thanks
Dave
