MonteC's Transmission Corner (For Info Only)
Old Apr 13, 2010 | 07:57 AM
  #81
MonteC's Avatar
MonteC
Originally Posted by [roger]
Hey MonteC.
I did changed my 46RE with another 46RE on my 1999 Dodge Ram Sport
but now I got both Transmission Temp light and the OD off lights on
it runs, but only 3 speed and it surges while shifting.
I got 30 days of warranty in-case it messes up
but how can I fix those problems?
You have the incorrect governor transducer installed on your trans. Install the correct one and the problem should go away.
Old Apr 13, 2010 | 07:59 AM
  #82
MonteC's Avatar
MonteC
Originally Posted by Sheriff420
So my transmission guy saying the optimum temp is 176º was right on the money then.
Mine hangs around 160º-170º when hot at idle with just a stacked plate style cooler like a b&m.
So was my guy right when he said that the stock coolers have a coating on the inside that breaks up over time and clogs up the works in the transmission? That is why he bypassed it all together and used just this cooler.
No they dont have a coating in them. Trash from the transmission clogs the small passages up. The passages inside the rad cooler are very small, like arteries in your body, they can clog up.
Old Apr 13, 2010 | 11:55 AM
  #83
[roger]'s Avatar
[roger]
governor transducer? what could that be? If this sounds noobieish then it is. Should I swap the Govenor from my old one? or what
and thankyou answering my question.
Old Apr 13, 2010 | 11:58 AM
  #84
Sheriff420's Avatar
Sheriff420
So he was on the right track in his description anyway then.
Have you ever bypassed the radiator cooler and run a stand alone cooler like mine is set up?
Old Apr 13, 2010 | 03:22 PM
  #85
ghost4321's Avatar
ghost4321
Hot side 180-210
Cold side 150-180
I put a temp gauge on mine yesterday, today it was running between 110-130F driving around town. Air temp is about 50F. The hottest it got was about 150F going uphill at about 30MPH, at 55MPH on flat ground it got down to 100F. Is this to cool? My gauge is on the cooler feed line at the end of the metal line under the hood. The radiator cooler is disconnected and the aux cooler appears to be factory.
Old Apr 13, 2010 | 04:10 PM
  #86
BlueBeast2's Avatar
BlueBeast2
Mine runs on the hot side even with a aftermarket cooler and deep pan
Old Apr 13, 2010 | 10:04 PM
  #87
MonteC's Avatar
MonteC
Yes. Do a search on governor pressure sensor, governor pressure solenoid. That should show you how to change them.
The governor pressure sensor or transducer needs to be matched to the computer. The transducer not only senses governor pressure but has a temp sensor also. The different sensors are not compatible to different computers.
A 96-99 should have the round metal sensor, 00/01 should have the black plastic sensor.
Old Apr 13, 2010 | 10:05 PM
  #88
MonteC's Avatar
MonteC
Every one i build.
Old Apr 13, 2010 | 10:10 PM
  #89
MonteC's Avatar
MonteC
Wow thats cold. I would get a temperature gun and verify what your gauge is reading. If you are infact running that cold on the hot side, i would clean out or replace the radiator and run the cooler lines back through the rad to warm that fluid up.
Old Apr 13, 2010 | 10:11 PM
  #90
MonteC's Avatar
MonteC
Some will. As long as you are under 230 you are good.
