MonteC's Transmission Corner (For Info Only)
Old Jul 7, 2010 | 08:43 PM
  #481
MonteC's Avatar
MonteC
Originally Posted by mpatrick19
Well after 2 wks. I got my truck back. After he tried everything non mechanically transmission related, he finally figured out that it was a bad valve body. I now have o/d, but the trans is shifting late, hard and feels like its falling into o/d. I figure I will try and adjust the t.v. cable and see what happens. I really don't want to take it back to him after the poor customer service I received.
Sorry. Its extremely difficult finding a good capable builder. Btw these valve bodies dont "go bad". Ive never had to replace one after i rebuilt it. If you take them apart, take every valve out, polish the bores and install the sure cure and wash all the crap out of them they are good to go.
Most shops dont touch the valve body though. They are scared of them, some will swap them out trying to get a transmission to work better.
Sounds more like a bad builder rather than a bad valvebody.
Old Jul 7, 2010 | 08:46 PM
  #482
MonteC's Avatar
MonteC
Originally Posted by CappinHoff
So which should I do?
1. More throttle opening = HIGHER line pressure and LATER, FIRMER shifts.
2. Less throttle opening = LOWER line pressure and EARLIER, SOFTER shifts.
3. WOT (Wide Open Throttle) = MAXIMUM line pressure and FIRM shifts at the engine redline.
number 2 just a tad.
Old Jul 10, 2010 | 11:41 AM
  #483
KBG's Avatar
KBG
Newbie here needing a little HELP!!!
Just picked up a 2001 Ram 1500 reg cab LWB 4x4 with a 318
Question is this.....The transmission will start out in 2nd gear pretty much every time I take off unless I manually shift it into 1st.....if I manually put it into first and then shift it back into drive as soon as the truck starts moving it will shift out of first fine and through all of the gears fine.....everything else works great and the truck only has 42000 miles on it and has never towed anything in it's life (matter of fact it doesn't even have a tow package lol).
governor pressure sensor & solenoid replacement needed???
thanks in advance!!!
Kevin
Old Jul 10, 2010 | 10:08 PM
  #484
Cummins413's Avatar
Cummins413
Default gas job tranny into a cummins?
hey, I was wondering if you could answer my question.... could I take the 47RE tranny out of a 2000 gas job, and put it into my 2000 cummins? Ive heard from a lot of people that its the same tranny, but I dont wanna do all the work just to find out it doesnt work....
thanks
Old Jul 10, 2010 | 10:19 PM
  #485
dodge15004x45.9's Avatar
dodge15004x45.9
2000 gas trannys are 46re not the 47re.
Old Jul 10, 2010 | 10:42 PM
  #486
Laramie1997's Avatar
Laramie1997
Now now, if it was out of the V10, then it would be the 47RE, and I do believe that the V10 runs on Gas...
Old Jul 11, 2010 | 07:02 PM
  #487
MonteC's Avatar
MonteC
If its a v10 it might work, its a 47re the bellhousings might be different, not sure. But the v8 gas motors, no its a 46re wont bolt up and wont hold up.
Old Jul 11, 2010 | 07:04 PM
  #488
MonteC's Avatar
MonteC
Kevin
Yep, change them out.
Old Jul 11, 2010 | 09:06 PM
  #489
Obiejuankinobie's Avatar
Obiejuankinobie
Hi my Tranny won't move unless it cool then it will only go about the length of a parking lot before all you hear is motor & whine from the transmission. It's at the Trans shop now. He starts work on it tuesday. Is there anything I should specifically ask for or just let him swap out for one he says he has on his stock shelf. 2001 Ram 1500 5.2LTR 2whl dr. I pull a motorcycle trailer with two bikes on it.
Thanks in advance Obie
Old Jul 12, 2010 | 10:20 PM
  #490
MonteC's Avatar
MonteC
id atleast get a sonnax sure cure and a gm conversion solenoid. Also invest in a precision of new hampton rv converter.
