MonteC's Transmission Corner (For Info Only)
Old Jul 30, 2010 | 10:34 PM
  #581
MonteC's Avatar
MonteC
Originally Posted by tcoz370
2001 Dodge Ram 1500 5.2L Extended Cab
Truck goes to park, reverse, neutral, drive no problem what so ever. However she wont shift outta first gear. Tried drivin around and getting it to shift by letting off it at different RPMs. Still stays in first.
Yes, I did do some research on the site. Nothing fit my problem 100% but some of the conclusions people came to for similar problems was to change the "govenor pressure sensor & solenoid" Anyone think that this is my problem or any ideas as to what it could be?
Just got a refurb PCM cause I had "No Bus" before...truck starts now and everything with the PCM just doesnt shift from first...maybe bad programming...are the shift points controlled by the PCM?
Feel free to throw any idea out there, thanks
So before the pcm change transmission worked fine? After pcm change transmission wont work. Correct?
  #582
BigRedRam95's Avatar
BigRedRam95
Originally Posted by MonteC
Does the truck shift into lock up? Does it shift into overdrive?
Yes the trans shifts fine goes in and out of overdrive fine no slipping. when going from neutral to drive it only take a sec to go into gear.
Old Jul 31, 2010 | 06:29 AM
  #583
ColoradoRamLover's Avatar
ColoradoRamLover
Originally Posted by J415
I asked Monte the same question when I rebuilt my tranny 2k miles ago and he said the same thing...now engines are a different story however.
Oh yess they are! But, it is nice to pop an engines cherry. Greatest smell in the world! Especially if its a Hemi!! haha anyways, I might have to deal with breaking in an engine. Not sure yet tho.
Old Jul 31, 2010 | 07:42 PM
  #584
m2hbvic's Avatar
m2hbvic
Hi Robert,
Sent you a PM w/ some GM tranny questions. THANK YOU.
Old Aug 1, 2010 | 01:47 AM
  #585
MonteC's Avatar
MonteC
If lock up and overdrive are working fine. i dont think you have anything to worry about. Clear the codes and see if they come back.
Old Aug 1, 2010 | 03:03 PM
  #586
BigRedRam95
If lock up and overdrive are working fine. i don't think you have anything to worry about. Clear the codes and see if they come back.
Ok this may sound stupid but how can I tell if the trans is going into lockup? What does lockup do?
It only goes into lockup in 3 and O/D right?
Now If lockup is what I think it is mine goes in. When the trans is locked out of O/D just after it shifts into 3 it sounds like it shifts again like it went into O/D but it did not then when I turn O/D on it shifts once more so I think it is going into lockup. Also how do I clear the code? I tryed to unhock the battery for 15min but the code is still there. Do you think I should replace the sensor just to be safe? I am going to take the pan off to put a deep one on anyway. Thanks for all your help.
Old Aug 1, 2010 | 06:24 PM
  #587
always_something's Avatar
always_something
MonteC, I asked a question a couple pages back about my tranny holding in first longer before shifting into sec. Well I had to drive my truck over to a buddys house to check all codes to see if I was missing anything else. I find the reason for the higher shift is it has no second. It goes from 1st -3rd, can't even manually put it in second. And it turns out buddys computer doesn't have the right number chip to read all the codes. Is this more serious than previously thought?
Old Aug 1, 2010 | 07:32 PM
  #588
tcoz370's Avatar
tcoz370
Yeah that is correct
Old Aug 1, 2010 | 09:57 PM
  #589
jKsled's Avatar
jKsled
Thanks for the continued help. Went through the whole thing again to the best of my ability. No leaks now with a new pump housing.
I haven't taken it in to use a scan tool yet to check out this "limp mode" problem, and now another problem developed. Originally, it would start in 3rd gear, and would manually shift into first and second. Wouldn't go into o/d. This was described to me as the limp mode. Now, however, it will only go into 1st gear.
It did this all of a sudden, I was driving in 3rd, when all of a sudden it started revving reallly high as it switched to 1st.
Funny thing is, when I have the selector in 1st, you can tell it's actually in gear. When it's in 2nd or Drive, it will only go in 1st gear, but it kind of coasts when you let off the gas, and has no engine braking.
I know it's hard to diagnose these problems online, but in your opinion, do you think this would be related to the electric "limp mode" issue still, or does it sound like something took a dump in the valvebody?
I'm looking through the valvebody as i'm typing this, and as far as I can see all the internals look normal?...?
Old Aug 1, 2010 | 10:11 PM
  #590
MonteC's Avatar
MonteC
Yep from what you describe its going into lockup. To change that sensor you have to change the o/d and lockup solenoids, along with the entire wiring harness inside the transmission.
