MonteC's Transmission Corner (For Info Only)
Old Jun 30, 2010 | 03:30 PM
  #461
CappinHoff's Avatar
CappinHoff
The issue I'm having is when I drive in the city with speeds 25-35 the tranny won't shift right away into the next gear. It stales and the RPM's increase. This however doesn't happen on the interstate when I gun it. Fluid is perfect, filter has been checked.
Old Jun 30, 2010 | 07:52 PM
  #462
72 Charger SE's Avatar
72 Charger SE
Originally Posted by BlueBeast2
There is no seal between the engine and TC at least not on mine. Also is should come out as 1 beings its bolted to the engine. Might be different on a 94??
No, there is no seal between the engine and the torque converter. However, there is a seal between the converter and the transmission pump, which can be damaged by pulling the engine with the converter still attached. The converter engages the input shaft and pump in the transmission, both of which could also be damaged by pulling the engine with the converter still bolted to the flex plate on the engine (depending on how much side force is applied by pulling the engine.)
Old Jun 30, 2010 | 09:34 PM
  #463
MonteC's Avatar
MonteC
Originally Posted by dodgeram07
1995 dodge ram 5.2 46rh
since i have had the truck i alway have to make sure the truck is in frist gear taking off.... like driving and stop at a stop sign i make sure i feel it down shift into gear,, if not it will bump in frist gear taking off.... i changed the fuild and filter it doesn't happen as much i think,,, time for smart blend?
no big deal but, also today i would not go into OD and the light on the OD button would come on i push it on and off no thing
turn the truck off and back on the OD light on the button came on when pushed and OD was working again
thanks jake
also how many hours would a good tran shop charged to put a Sure Cure kit from sonnax?
Id say probably 2-3 hours. I would put a bottle of red in and see what happens.
Old Jun 30, 2010 | 09:42 PM
  #464
MonteC's Avatar
MonteC
Originally Posted by USAFretired
MonteC, In my son's 94 1500 automatic we just replaced the engine with a junk yard engine. Long story short. I pulled the torque converter off with the engine.(not sure why because I have done many engine swaps) So I replaced the seal and put it back on after I removed it from the engine. Well after we finally got the truck going I now have a serious leak from that seal I assume. is there something else besides that seal I need to be looking at? One other thing is it has a good leak from the selector shaft seal. With the tranny out is that a big deal to replace? You are a good man for taking the time to help people like us out. Thanks. I guess I should add that its the 5.9 engine 4x4. anything special I need to know before I drop the tranny. Like should I drop the transfer case with it or leave it there. Sorry I am new to Dodge trucks. Thanks Neil
Pull it back out and replace the seal and the pump bushing. Your gonna need to pull the pump out. Just stand the trans up on its tailshaft housing, not pushing on the output shaft. yank the pump out after removing the pump cover bolts. Flip the pump over and take out the pump stator bolts. Knock out the old bushing and press in a new one. Then press in a new seal.
Ive actually seen quite a few front pumps leak after a motor was removed with the torque converter attached to the motor. Dont know why. But a new bushing and seal cured it.
Old Jun 30, 2010 | 09:43 PM
  #465
MonteC's Avatar
MonteC
Monte on a basically stock tranny. Had some stuff replaced in the past. How long will it hold up doing WOT runs?
Its hard to say. Very hard question to answer.
Old Jun 30, 2010 | 09:45 PM
  #466
MonteC's Avatar
MonteC
Originally Posted by markc522
Thanks for the info! What is the tv cable? Also where can you find smart blend? I've looked at a few part stores and haven't found any yet?
The tv cable is the cable that goes from the transmission to the throttle body.
http://www.amazon.com/Smart-Blend-40...948712&sr=8-16
Old Jun 30, 2010 | 09:48 PM
  #467
MonteC's Avatar
MonteC
Adjust your tv cable.
Old Jul 1, 2010 | 12:01 AM
  #468
elcheeko's Avatar
elcheeko
noob ? here but how do i adjust the tv cable and im havein the same prob.
Old Jul 1, 2010 | 01:20 AM
  #469
CappinHoff's Avatar
CappinHoff
I found this on the TV Cable.
http://bionicdodge.com/Download/Dodg...Adjustment.pdf
Will this work for a 2000 Dodge?
Old Jul 1, 2010 | 07:10 AM
  #470
USAFretired's Avatar
USAFretired
Thanks MonteC. That sounds easy enough. I got the tranny out last night. I see in the manual it says "special tool" to remove bushing but I guess you can just drive it out like you said. Now to find that part # for the bushing. I have the seal on order. Thanks again.
