Put in new wheelbearing but weird noise?
Old Apr 6, 2010 | 07:51 PM
yakkier's Avatar
yakkier
Default Put in new wheelbearing but weird noise?
Hey i gots a question, i just did my driverside wheelbearing and U joint and now if i hit a pump it will Roar, almost like if you're running off the road going down the freeway hitting those little "speed rutt's on the side of the road"..
I cant tell where it's coming from, the hub is torqued to spec, both sides and the U joints are solid.
I checked the rearend and yes my shackle is still broken i know that but it's not putting any stress on the driveshaft or tranny, and it only does it when i hit bumps, almost like the axle shaft is slipping inside the hub but i know it's the right size because it wasnt loose at all sliding it on.
Idea's ?
Old Apr 6, 2010 | 08:40 PM
dhvaughan's Avatar
dhvaughan
what about a brake caliper or pad banging around and hitting something ?
Old Apr 6, 2010 | 08:45 PM
004x41500's Avatar
004x41500
it could be the rear end getting extra strain when you hit a bump since you shackle is still broke, until you get your shackle fixed, I would say that extra strain on your rear end is being caused by a broken shackle. Id fix that first, since you already know that its bad.
just my $0.02
Old Apr 6, 2010 | 10:43 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
damn yak you just cant catch an effin break can ya
Old Apr 6, 2010 | 10:55 PM
95RAM360's Avatar
95RAM360
you put the washer back on before the hub nut right?
Old Apr 6, 2010 | 11:46 PM
yakkier's Avatar
yakkier
What washer? i never had a washer on it on either side and neither one of the hubs came with new ones......
Old Apr 7, 2010 | 06:41 PM
xxxcowxboyxxx
ummmm............yeah.....you need that......
Old Apr 7, 2010 | 08:40 PM
yakkier's Avatar
yakkier
What size washer do i need? any one got any pics?
Old Apr 7, 2010 | 08:51 PM
xxxcowxboyxxx
