getting a wrecked 2500
Old Apr 11, 2010 | 10:56 PM
offroadjosh's Avatar
offroadjosh
Default getting a wrecked 2500
I am getting a 2500 with the v10 that has been rolled. Everything but the body is good. Has less than 100k on it and is a 97 i think. So i dont have much time to search on here but what can i use off it? I am thinking the dana 60s the t-case and the tranny? I want easy bolt in(no extreme fab work) I am pretty sure the axles are easy right? What about the tcase and tranny? It has the v-10 and a 5 or 6in lift on it and 35s axles have 456s and Detroit lockers. Its a short box club cab like my truck. It is a sport too. So it short i want to put the 3/4 ton axles in my truck and if its easy enough the tcase and tranny. What about the engine?
Josh
Old Apr 11, 2010 | 11:22 PM
95MaroonMonster's Avatar
95MaroonMonster
i'd go for it...those axles would be a killer upgrade...and IIRC...the V10/cummins trucks had a dana 70 rear and 60 front....
the trans won't bolt up b/c the cummins/V10 trans had a different bellhousing pattern....but the case probably would if the input shaft is the same size/spline count (and that case would make it much easier to put the axles in b/c of the tcase end of the driveshafts)
now, the motor, i really don't know, it could be done, it would be much easier though if the trucks were the same year...
Old Apr 12, 2010 | 01:13 AM
dakotas ram's Avatar
dakotas ram
jus take your body and put on it
Old Apr 12, 2010 | 01:18 AM
offroadjosh
Haha I thought of that... How hard of a swap would that be?
Old Apr 12, 2010 | 01:23 AM
dakotas ram
dunno
Old Apr 12, 2010 | 01:34 AM
RamSport97's Avatar
RamSport97
Probably less time than if you were to yank all the parts you want off the 2500 lol. Then you could sell your rolling chassis, motor, trans for a decent sum of money.
Old Apr 12, 2010 | 01:52 AM
offroadjosh
Damn I might just do that.... For sure I am grabbing the axles if everything goes right. So then I will have my 5in lift and 35s lol with 1 ton axles and 456s with lockers. Be pretty bad *** that way.
Old Apr 12, 2010 | 07:25 AM
95RAM360's Avatar
95RAM360
if you have at least 5 friends to help you, you could swap the body over to the new truck....get a nice breaker bar, or power tools, undo all the lines, harness, body mounts, and it should come right out....could have it done in a weekend
Old Apr 12, 2010 | 08:37 AM
MonteC's Avatar
MonteC
How is the tailgate?
Old Apr 12, 2010 | 03:21 PM
offroadjosh
Hahaha oh man, I just may.
