Fuel filter, or not fuel filter?
Old Apr 13, 2010 | 07:30 PM
Qaiphyx's Avatar
Qaiphyx
Default Fuel filter, or not fuel filter?
Dodge ram 1500 V6 EFI, starts cold but while still cold if you put it in to gear the engine dies. Once it warms up the engine will go fine.
its a 96
Old Apr 13, 2010 | 08:02 PM
J415's Avatar
J415
The fuel filter in these truck are built in the fuel pump, so it's not the fuel filter.
Old Apr 14, 2010 | 11:31 AM
Qaiphyx's Avatar
Qaiphyx
so maybe the fuel pump is bad? Injectors are new.
Old Apr 14, 2010 | 12:15 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Before you start it you should hear a wine coming from the back end of the truck.
Old Apr 14, 2010 | 12:58 PM
Sport1500's Avatar
Sport1500
Surprising these don't have an external fuel filter as well. I was looking on AutoZone's site for replacement filter prices and didn't see anything and thought that was weird.
Rob
Old Apr 14, 2010 | 01:51 PM
aim4squirrels's Avatar
aim4squirrels
Clean the throttle body and report back.
Old Apr 14, 2010 | 02:10 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Rob
There is a screen at the base of the fuel pump assy, an internal filter, and then the pressure regulator, which acts as a third stage filter. They're pretty well covered.
Aye-aye, Cap'n!
Old Aug 19, 2010 | 02:43 PM
Signal 2's Avatar
Signal 2
Looking for an update or resolution to the OP's problem. Have the same.
Old Aug 19, 2010 | 09:28 PM
Terribly's Avatar
Terribly
Dodge came out with a tsb to reprogram the ecm for the cold start problem. Mine is a manual but when i started it, it would rev up and then die, but if i held my foot on the pedal to about 2000 rpm until it got warm, it would idle. they told me there is a reprogram that they have to do and the problem was solved!
Old Aug 19, 2010 | 10:49 PM
dhvaughan's Avatar
dhvaughan
idle problems are often IAC or TPS.
check fuel pump by testing pressure at the rail with a gauge, should be 49psi.
