Quick Question
Old Apr 17, 2010 | 08:55 PM
Cdozier's Avatar
Cdozier
Smile Quick Question
hey fella's
i have a quick question
I just picked up a 1998 ram 2500 with a 5.9 gas engine. The truck has 182,000 miles and i was wondering what weight oil would yall run in the truck...the engine dosnt sound tired or anything but the oil pressure when cold and at idle is above 40psi but once the engine warms up a little it drops a little below 40psi and maybe goes a little above 40psi while driving highway speeds when warm..
Any info would help...thanks everyone!
Old Apr 17, 2010 | 09:04 PM
97tn4x4's Avatar
97tn4x4
I have the same motor and almost the same miles and I run 10-30
Old Apr 17, 2010 | 09:10 PM
Cdozier's Avatar
Cdozier
i was thinking about useing 20-50...no yes?
Old Apr 17, 2010 | 09:30 PM
dhvaughan's Avatar
dhvaughan
welcome to df. that sounds like a nice truck. ir'll have dana 60's front and rear which gives you lots of strength and options for gears, lockers, etc.
your oil pressure is perfectly normal and it doesn't make any difference which oil you run. the thicker 20/50 might leak a little less and might hold a tad higher oil pressure, but any modern oil is fine.
Old Apr 17, 2010 | 09:35 PM
97tn4x4's Avatar
97tn4x4
I've always been told that synthetics leak more than conventional. Is this true cause I run synthetic blend.
Old Apr 17, 2010 | 09:37 PM
RamIT.CntryBoy's Avatar
RamIT.CntryBoy
the 20w40 sounds good esp. for the summer heat but only if ur really gunna DRIVE the truck hard. if its ur daily driver i would stick with 10w40. thats all you need. there is no need for 20w50 (a very thick oil) when the hardest u drive it is revin it out once in a while.
Old Apr 17, 2010 | 09:52 PM
GeorgiaDodge's Avatar
GeorgiaDodge
It gets hot down here in the south and i run my truck hard with 10w30 and it holds steady around 45-50psi.
Old Apr 17, 2010 | 09:58 PM
Cdozier's Avatar
Cdozier
right on..thanks for everyones help..i guess ill stick to 10-40...i just didnt know if the low oil pressure was bad or not..
Old Apr 17, 2010 | 10:31 PM
BlueBeast2's Avatar
BlueBeast2
I always run 10-30 in everything. I have always used normal oil as well but that will be changing. I have Royal Purple to put in at some point
Old Apr 17, 2010 | 10:41 PM
RamIT.CntryBoy
10-40 is a good idea. If it seems like you have low oil pressure u shouldn't go to 20-50 b/c it will drop your pressure even more cuz of how thick it is but try out the 10-40 and see how the pressure is
