permanently locking CAD
Old Apr 18, 2010 | 09:00 AM
dhvaughan's Avatar
dhvaughan
i've not had to do this job yet, so no personal experience. lets play 20 questions.
how do you pluck the inner shaft out?
do you just grab the end and slide it out, or do you have to release it in some way?
does it have to come all the way out, or at least past the cad opening ?
does the big bushing just pry out of a seat and tap back in, sort of like a seal ?
Old Apr 18, 2010 | 09:18 AM
zman17's Avatar
zman17
Retired Moderator - RIP
yes,yes and yes. And actually a seal is more of a pita. Also the shaft does not have to be released in any way.
Old Apr 18, 2010 | 09:49 AM
dhvaughan's Avatar
dhvaughan
i wish i had done this when i replaced wheel bearings.
Old Apr 18, 2010 | 10:43 AM
zman17's Avatar
zman17
I also learned the hard way, like with plenum gasket replacement.
Old May 1, 2010 | 12:00 PM
willstruck's Avatar
willstruck
I'm about to replace those bushings today, what all do I have to take apart to get to the shafts?
Old May 7, 2010 | 06:41 PM
1994ram1500's Avatar
1994ram1500
how did the install go willstruck?
Old May 8, 2010 | 07:24 AM
olyelr's Avatar
olyelr
Fawk replacing all those parts. Just delete the entire assembly. http://www.emsoffroad.com/store/inde...aa98896edd1310
Sure, your shaft will spin all the time, but that will not cause any issues unless there already is some. And you will not use a LOT more gas... maybe like a half mile per gallon more, but with a Dodge that isn't much of a big deal.
And yes, Dodge "deleted" the CAD in the 2002 2nd gen (3/4 ton) and all the 3rd gen 3/4 tons. They knew the setup was junk.
Old May 8, 2010 | 01:52 PM
willstruck's Avatar
willstruck
I thought I'd be able to get the bushing anywhere, but apparently not. I haven't tried the stealership, but I tried O'Reillys/CSK, Autozone, NAPA, Pep Boys. I know I can order it from quad4x4, I should have last weekend. So, basically I haven't gotten the parts yet, so I haven't done it yet. It should be pretty straightforward, I just don't really know how to go about pulling the hub off, or where that bigger bushing goes.
The CAD delete is interesting, anyone on here done it?
Although, I would like 2low like with the cable locking setup.
Old May 8, 2010 | 09:38 PM
1994ram1500
you can make your own cable locking setup i did for about 30 bucks. i got the bushings in yesterday from quad 4x4 ill be doing it after teh 16th (graduation) looks like i gotta do fuel pump too, though
Old May 9, 2010 | 08:49 PM
willstruck's Avatar
willstruck
You'll have to do a write up, with pics. I would rather make one than buy one.
