vacum line
Old Apr 19, 2010 | 08:14 PM
HuntFishBikeMt's Avatar
HuntFishBikeMt
Default vacum line
I did the plenum plate paid 14 bucks for the plate and an half hour of work all done (too much scotch in me to buy something I can make) any way all went smooth on the install until I found a vacuum line I do not remember seeing when I torn it apart so was wondering if someone could tell me where it goes? it's not regular line it is hard white plastic type with a 90 degree elbow on the end and appears to run down the back of the motor. Also changed out the governor pressure sensor added a drain to the tranny all in all everything went very smoothly just have to run the new plug wires and go get a tb gasket (i forgot to get it) and see how she runs
Thanks for all the help Randy
2001 1500 4x4 with the 360
Old Apr 20, 2010 | 08:43 AM
HuntFishBikeMt
please someone help-
Old Apr 20, 2010 | 09:07 AM
95RAM360's Avatar
95RAM360
goes to the front of the throttle body if im not mistaken.
Old Apr 20, 2010 | 10:56 AM
jamesnb's Avatar
jamesnb
It sounds like it engages the four wheel drive. Is there an outlet on the intake manifold thst it would connect to? If not, is there a fitting it would connect to on the vacuum line running from the intake to the fire wall? If you could post a picture it might help.
Old Apr 20, 2010 | 05:06 PM
HuntFishBikeMt
Sorry did not think of taking a pic or two. I only remember seeing 3 vac ports on the keg all 3 are hooked up also the 1 on the tb is hooked up this line is maybe only 1/8" dia. at most maybe smaller
http://www.facebook.com/album.php?ai...00000508595587
Old Apr 20, 2010 | 05:15 PM
HuntFishBikeMt
Sorry about the last 1 hope this works kinda computer dumb
http://s736.photobucket.com/home/huntfishbikemt/index
Old Apr 20, 2010 | 05:20 PM
PurplDodge's Avatar
PurplDodge
Use the "IMG Code"
Looks like the white line that goes down to the transfer case to engage the front axle.
Old Apr 20, 2010 | 05:28 PM
HuntFishBikeMt
Thanks purple but do you know where it hooks into on the motor I am not finding any open ports
Randy
Old Apr 20, 2010 | 07:04 PM
yakkier's Avatar
yakkier
Top right of the engine towards the back, will be either a 3 port or 2 port black silenoid
Old Apr 20, 2010 | 07:58 PM
jamesnb's Avatar
jamesnb
Trace the vacuum lines from the intake manifold back to the firewall. One of them will have a stub which that line is supposed to plug into.
