ABS & Brake Light Help
Old Apr 21, 2010 | 10:16 PM
florida9's Avatar
florida9
Well the ABS & Brake light came back on about a hour ago when i started the truck so should i try replacing it or maybe try to clean the front one?
Old Apr 22, 2010 | 01:09 AM
dhvaughan's Avatar
dhvaughan
Originally Posted by bigtman07
Where is the sensor that is on the tranny? Is it easy to get to?
tail housing of trans on 2wd. tail housing of t-case on 4wd (i think). anyway, its at the rear, and has an elcctrical plug attached. very easy to get to and change. also cheap, about $16 at autozone. a little bit of trans fluid will run out when you remove it, so swap it sort of quick.
Old Apr 22, 2010 | 01:13 AM
dhvaughan's Avatar
dhvaughan
if it was me i'd just replace it and move on.
if money is tight, do a search on ABS and Brake and see how many people posted the solution as the trans sensor vs the diff sensor. i think the majority is rear diff.
Old Apr 24, 2010 | 09:18 PM
florida9's Avatar
florida9
Well 2 days ago i replaced the sensor today the ABS & Brake light came on when i started the car and then i turned it off a few times and back on and it went away its still doing the same crap now what??
Old Apr 26, 2010 | 08:58 AM
florida9's Avatar
florida9
Anyone have any clue what to do now?
Old Apr 26, 2010 | 09:33 AM
Relex's Avatar
Relex
Originally Posted by yakkier
Might be a speed sensor problem, i have 33's which are quite bigger than stock and my speedometer isnt off more than 1 mph.
How did you manage that? Mine is off by 5 with 33"s.
Old Apr 26, 2010 | 11:10 AM
Take it to your favorite auto parts store, that has a scanner, and have them tell you what code is being set. You can "guess" and throw parts at it from now till doomsday, and still not get the right one.
Find out what the computer thinks the problem is, and then fix it.
Old Apr 26, 2010 | 09:46 PM
florida9's Avatar
florida9
My friend has a scanner i already scanned it 3 different times and it said it had found no codes
Old Apr 26, 2010 | 10:36 PM
yakkier's Avatar
yakkier
Couldn tell ya but i got a speedin ticket to prove it, state trooper clocked me goin 85 and i was goin 85 lol
Old Apr 27, 2010 | 02:37 PM
bigtman07's Avatar
bigtman07
Usually only an ABS code reader will work. The only place I have found to have one is the dealer.
