Axle Nut Problems
Old Apr 21, 2010 | 06:48 PM
Pete379's Avatar
Pete379
Default Axle Nut Problems
I've got a bad axle seal on an 01 ram 2500 and went to pull the axle nut today to replace the axle seal and it won't budge what so ever. I soaked it with wd40. I pulled the ratchet stood on the damn thing and finally tried to break it loose by pushing the ratchet up with my 3 ton floor jack and only succeeded in lifting the front of my truck up. I don't have a 3/4" impact and ain't got the money to buy one. does anybody have an Idea on how to get that damn nut off. It had ball joints done before I bought the truck and I'm sure they just hammered the living hell out of that nut with an impact which is why that seal went bad. I just need to know if anybody's got any idea on how to get the nut off.
Old Apr 21, 2010 | 07:02 PM
yakkier's Avatar
yakkier
3/4' breaker bar with 1 - 11/16's socket and a 4 foot piece of pipe.
Old Apr 21, 2010 | 07:15 PM
seabass202's Avatar
seabass202
if there is a local shop you use somtimes, you might be able to get them to throw an impact on it for a couple bucks. just have them snug it back up for the careful drive home.
Old Apr 21, 2010 | 07:23 PM
yakkier's Avatar
yakkier
impact wont budge them usually.
Old Apr 21, 2010 | 07:33 PM
VEETEN's Avatar
VEETEN
Try the pipe as Yak suggested. and a real good penetrating oil PB, deep creep, knocker loose. WD40 is good for squeeky door hinges..
Welcome to the DF
Old Apr 21, 2010 | 10:08 PM
KYHI's Avatar
KYHI
Originally Posted by yakkier
3/4' breaker bar with 11/16's socket and a 4 foot piece of pipe.
Now that is what i would call tight..
Old Apr 21, 2010 | 10:59 PM
Gerehead8's Avatar
Gerehead8
Then you need a bigger impact.
Old Apr 21, 2010 | 11:23 PM
Cheat's Avatar
Cheat
It aint big enough till theres a chance of a broken wrist.
Old Apr 21, 2010 | 11:59 PM
JackJ's Avatar
JackJ
When I pulled mine off, I used an impact wrench and took about 3-5 min of running the damn thing to get it to come loose, witch is odd because there is only something like 200 ftlb max on that thing if I remember correctly and I am used to breaking 400 plus ftlbs of torque on a fairly regular bases. I tried the breaker bar and pipe deal and got no where with it, then again it may have been easier if the tire had been on the ground. Unless I am thinking of another axel nut it is an 1-11/16 nut. I had to got buy mine from my FLAPS. Luckily I saved my self some money and found the axel nut that said Dodge on it, and having to buy a bunch of different sizes to get the right one.
If you have access to a compressor that will run air tools, try to see if you can rent an impact wrench, if not, just yank like hell and it will come off eventually.
Old Apr 22, 2010 | 12:41 AM
yakkier's Avatar
yakkier
yep 1 - 11/16 is what i ment, i edited my post from earlier
