ENGINE Light!
Old Apr 25, 2010 | 12:36 PM
quadracer18's Avatar
quadracer18
Default ENGINE Light!
So i just replaced my drivers side head gasket because i mistakenly thought radiator fluid was leaking from it down the side of my block. After replacing the timing cover gasket, the problem is fixed. However, after i did the headgasket, i got a check engine light. I took the truck to aamco and the guy checked over the motor and did compression tests etc. (everything with valves and compression checked out good) He came to find that cylinder 7 had a misfire. To me, the truck runs great... So he recommended i change my plugs, wires, ditributor cap and rotor. I did all of that and disconnected the battery to clear the engine light but it came back on today. ANY ideas??? He said that it sounded like an ignition issue, thats why he reccommended me to put new plugs, etc in.. Im at a loss.....
Old Apr 25, 2010 | 12:41 PM
Maxx_Magnum's Avatar
Maxx_Magnum
There's a TSB in the DIY section regarding re-routing the plug wires correctly because of misfiring... give that a look over and see if that makes a difference. Get the easy things outta the way first
https://dodgeforum.com/forum/2nd-gen...lug-wires.html
Old Apr 25, 2010 | 01:00 PM
quadracer18
so your saying the wires needed to be routed a specific way or it can cause interference with one another and cause misfires?? that seems rediculas lol
Old Apr 25, 2010 | 01:31 PM
J415's Avatar
J415
Yup, reroute the wires. Unless you feel like taking it to a shop so they can do it for you at $90 an hour.
Old Apr 25, 2010 | 01:56 PM
quadracer18
so, i rerouted the wires and the engine light is still on.. any other ideas. The truck runs great, i cant see how the garage says i have a misfire..
Old Apr 25, 2010 | 02:04 PM
Maxx_Magnum
unhook your battery for a few minutes to reset the light, if that fixed the problem it shouldn't come back on
Old Apr 25, 2010 | 02:35 PM
quadracer18
thats what I did and the light came back on. Is there any other ideas???
Old Apr 25, 2010 | 04:18 PM
Cheat's Avatar
Cheat
Take it to a autozone and get the code. I dont trust the little quick lube deals, Always get the code, Investigate yourself dont let someone behind a counter do it for you.
Old Apr 26, 2010 | 05:52 PM
quadracer18
Bump!! i need help guys!!
