Front Differential Leak
Old Apr 26, 2010 | 07:26 PM
J1955610's Avatar
J1955610
Default Front Differential Leak
I think i have a link on my 95 Dodge Ram 5.9L 360 V8. Its leaking at the front differential, which i had filled today.
Is it leaking cuz the place filled it too much? Or is it a seal? etc etc?
I don't use the 4H or 4L drive. I keep it in 2 wheel drive.
Any input would be great.
Old Apr 26, 2010 | 07:27 PM
Relex's Avatar
Relex
Where is it leaking from? The diff cover, or the right or left where the axle shafts come out?
Old Apr 26, 2010 | 07:32 PM
J1955610's Avatar
J1955610
The diff cover
Old Apr 26, 2010 | 07:55 PM
Simple fix really.... Pull the cover, clean both mating surfaces (cover plate, and diff housing), run a bead of rtv around the diff housing, let it sit for five to ten minutes, then put the cover back on, and tighten the bolts. (use the same kind of pattern for tightening the bolts that you would for tightening lugnuts) Top it off with fresh fluid.
End of problem.
Old Apr 27, 2010 | 07:03 AM
J1955610's Avatar
J1955610
Thank you! I looked up how to do it and it looks relatively easy.
One question. Does the RTX work better than a differential cover gasket? I was looking at advance auto parts and came across this:
http://shop.advanceautoparts.com/web..._1197347510___
what do you think?
Old Apr 27, 2010 | 07:58 AM
95RAM360's Avatar
95RAM360
i never used gaskets on my diffs, just RTV. and ive had no problems, and i offroad all the time with no water contamination.
Old Apr 27, 2010 | 12:52 PM
I am right there with 95RAM360, for diff covers, I never use a gasket. The RTV actually seals it better. There are no alignment issues, such as you may have with the central axle disconnect system. (I did put that gasket back in there.... dealer only part though.)
