Front end problems
Old May 1, 2010 | 07:25 PM
Ramt0ugh85's Avatar
Ramt0ugh85
Default Front end problems
Hello. I just got a 1997 dodge ram 4x4 that was wreaked in the front. I had to replace the whole front axle and steering. I did this and it drives perfect. However, it makes this bad screeching sound from both front wheels. After about 4 or 5 days of driving it, the top 3 lug nuts on the driver side tire pop off! I have replaced both wheel bearings, brake pads/ rotors and it is still screeching. Any help would be great! Thanks
Old May 1, 2010 | 10:40 PM
Did you use any kind of anti-squeal compound on the backing plates of the brake pads?
Old May 1, 2010 | 10:43 PM
Ramt0ugh85's Avatar
Ramt0ugh85
Yes i did use the compound
Old May 1, 2010 | 10:45 PM
I get really generous with that stuff when doing brakes.... I use the stuff that comes in a spray can.
Does the sound change when you step on the brakes? If so, how? Better? Worse?
Old May 1, 2010 | 10:53 PM
Ramt0ugh85's Avatar
Ramt0ugh85
it stays about the same. brakes fine.
Old May 1, 2010 | 10:57 PM
Are the splash shields rubbing against the rotors? Does the sound vary with vehicle speed?
Old May 1, 2010 | 11:50 PM
Ramt0ugh85's Avatar
Ramt0ugh85
The sound gets faster with vehicle speed. almost cant hear it at 50 mph
Old May 2, 2010 | 12:32 PM
Have a look and see if the splash shields aren't contacting the rotors. Something that moves is rubbing on something that doesn't. Might have to pull the tires to get a good look. (and would probably be the best plan.)
Can you jack up the front, yank the tires, turn the parts, and hear anything that way?
Old May 2, 2010 | 01:03 PM
dhvaughan's Avatar
dhvaughan
lug nuts popped off ? and screeching ?
something's seriously wrong. like said, get it up on jack stands and rotate the wheels. look/listen for something rubbing. something's not fitting right...
what does popped off mean ? came loose ? stripped out ? lugs broke off ?
Old May 2, 2010 | 03:47 PM
95RAM360's Avatar
95RAM360
they popped off the new wheel hub assembly??
