Trailer wiring.
Old May 3, 2010 | 02:59 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Default Trailer wiring.
SO I went to use my 7 pin round and it wasn't getting much juice to the trailer. It was so little you could hardly see the lights flashing on his trailer my truck lights where bright as every.
I'm thinking it has to be the 7 pin it self a few of the conectors are mussed up inside.
I went to pep boys and picked up a trailer plug but before I cut the tail off the old plug and put this new one in I need to know the colors wire code coming from the truck itself.
Just to add some more info this is what I picked up from pep boys. http://www.hopkinstowingsolutions.com/doc/47185.pdf
Old May 3, 2010 | 03:41 PM
dodgeboy1979's Avatar
dodgeboy1979
hope this helps
Old May 3, 2010 | 04:49 PM
dodge15004x45.9
Is that coming from the truck? I need the one coming from the truck to the plug if that makes sense lol.
Old May 3, 2010 | 04:56 PM
dodgeboy1979
I don't understand?
Old May 3, 2010 | 05:01 PM
dodge15004x45.9
Ok my plug is messed up. I got a new plug and I want to wire the new plug into the factory wiring.
I need to know which wire is which coming from the truck to the plug.
Old May 3, 2010 | 05:09 PM
dodgeboy1979
the color codes i gave you should be what your truck has going to the back.
Old May 3, 2010 | 05:11 PM
dodge15004x45.9
Ok ill have to go give it a look.
Old May 3, 2010 | 05:13 PM
dodgeboy1979
i will take a look at mine too
Old May 3, 2010 | 05:48 PM
dodge15004x45.9
Well I just looked at the 7 pin and four pin.
7 pin has the following wires;
Black with red tracer
Purple
blue
red with orange
and 2 black wires
green with a brown tracer
4 pin
black with yellow
brown with red
green with brown
black
Old May 3, 2010 | 07:44 PM
dodge15004x45.9
BUMP need this fixed for this weekend.
