Any engine swap gurus on here
Old May 7, 2010 | 12:55 AM
BIGRED97's Avatar
BIGRED97
pull the intake check the plenum, rear main seal, rather all the seals, much much easier when outside the truck can get it all done in less than 1/2 the time.
just a reminder, i know when i get into projects i get so into doing i forget sometimes the smart/simple things that should be done first
Old May 7, 2010 | 01:15 AM
silverbullet-dodgeram's Avatar
Originally Posted by CPTAFW163
just make sure every sensor is connected. Then you will be fine. The only thing you might need to do isget a different crank position sensor, and cam position sensor for YOUR YEAR of truck. They have different connector tips for different years.
I know...I had to replace my wiring harness when i had a fire under my hood. long story, no fault of the truck.
Or you can just splice so the connectors fit. But make sure that you have all connectors connected, and there will not be a problem. If you have any problems, just snap a quick pic and post here or PM me. I can help with the underhood wiring.
lol can u help me? im not getting any spark to my plugs and ive pretty much determined the two wires going to the coil aint telling the coil to fire. but ive spliced the wires on the crank sensor? (the one in the bell housing) any ideas? need more info just ask me ill tell u what eve u need to know. i swapt the motor a month ago and aint heard it run yet so any help is appreciated
Old May 7, 2010 | 09:59 AM
TorqueAutoMotiv's Avatar
TorqueAutoMotiv
Yea Im pretty detailed in what im doing I recently rebuilt my GTP grand prix from the ground up made a few mistakes and hopefully leanred from them
I think ill just throw 3500 on both of them and the one that sells first wins
Im not really a brand guy I think all companys make certain cars that are crap and others that are good solid rides
Old May 7, 2010 | 05:39 PM
TorqueAutoMotiv
well All i can say is these are pretty decent to work on
radiator is out/shroud
ac comp/power steering/alt are all out
now i guess is where the real fun starts
When i pull it does it have to come out the front or just forward and straight up? im still a few hours away from that and my picker isnt here yet
Old May 7, 2010 | 05:55 PM
however you can get it out. Keep in mind, that the truck is sorta tall, so, going over the radiator support might be interesting. Make sure you keep your chains and such short, so the hook on the picker is close to the engine, otherwise, you may not be able to lift it enough to get it over.
Also, MAKE SURE that the legs extend out further than the arm with the hook. BAD things happen otherwise.
Old May 7, 2010 | 06:43 PM
TorqueAutoMotiv
Im thinking im gonna pulle the tires and lower it on to stands
Im pissed though bought a new coupler for my compressor and its the indtrial style not auto so im doing all the wrenching by hand time to head to the store and get the right one and a few other things
