Brake job parts list
Old May 12, 2010 | 07:16 PM
  #31
redheadhunter21's Avatar
redheadhunter21
Its your money if your bearings and seals are good and your having no problems I would keep them and just repack the bearings.
Old May 12, 2010 | 09:19 PM
  #32
They really aren't that expensive. (in the overall scheme of things, what with 90 dollar rotors....) Having everything new is kinda good for the peace of mind too.
Old May 13, 2010 | 04:44 PM
  #33
CPTAFW163's Avatar
CPTAFW163
you know...you can input your make/model/year/engine/drivetrain in summit to make sure the application fits the part.
I would call them to be sure.
I would also not waste my money on drilled and slotted rotors. Unless you have added performance parts that create a NEED for stopping faster, then it is a waste of money. Good brake pads and turning the rotors will be fine.
With the cash you are spending here, you could get a SCT and tune frome hemifever for 275.
--Dan
Old May 13, 2010 | 04:46 PM
  #34
Gary-L's Avatar
Gary-L
Veteran: Navy
--Dan
Not only that, but drilled rotors have a tendency to crack. They're best left to use on motorcycles.
For greater stopping power, install the ¾-ton rear wheel cylinders. No regrets and it's an affordable mod.
Old May 14, 2010 | 10:55 AM
  #35
notanexit7's Avatar
notanexit7
Originally Posted by dhvaughan
link/pic ?
early model 2wd had rotor with hub 94-?
last couple of years 00-01 switched over to 4wd parts - sealed bearing/hubs and slip over rotors.
My 99 still has the hub/rotor. I really with I had the rear disks like the late 01's do. I just finished up replacing my shoes and cylinders on the drums and my god what a PITA.
Old May 14, 2010 | 11:11 AM
  #36
Having the right tools makes it SO much easier. Brake spring pliers is my personal favorite. Granted, changing slave cylinders can be challenging..... brake lines tend to break, rather then unscrew..... but, consider where they hang out. Not exactly an environment conducive to staying clean, and rust free.
Old May 14, 2010 | 11:27 AM
  #37
Gary-L's Avatar
Gary-L
Veteran: Navy
That's why I clean them up well and use a bit of anti-seize on the threads.
