Doing a Hemi Swap in 1997 5.2
Old Nov 3, 2018 | 11:41 AM
srg1978's Avatar
srg1978
Default Hemi swap
Hi folks. I have an 02 3/4 with 5.9 gas. I want to do a hemi swap but after reading this not sure now. Now I'm reading build a 408. Am I using the 5.9 magnum block????
Old Nov 3, 2018 | 02:32 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
This is an 8 year old thread. I'm in the process of doing a 6.4 swap in my 01 2500. Doing a 408 you keep the 5.9 block, just shave off some metal .30 over
Old Nov 3, 2018 | 04:14 PM
And replace the crank with one with a longer stroke.
Old Nov 3, 2018 | 04:52 PM
MoparFanatic21
Yes but tried to keep it simple as the OP does not seem to be much knowledge in the engine department (no offense! We all started there). Not to mention pistons, valves, heads, and MAYBE a turbo
Old Jun 9, 2020 | 11:18 PM
Casy Carver's Avatar
Casy Carver
Default Hemi swap
I have a 97 Dodge Ram 1500 and an 05 Dodge Ram 1500 complete with hemi and everything. I want to swap my 97 body over to the 05 frame. What all will I need to be able to hook everything up and be able to drive the truck. Someone mentioned a special harness for the steering components
Old Jun 10, 2020 | 10:25 AM
MoparFanatic21
Won't work. Well I should say it will work with a lot of fabrication and it isn't worth it
Old Jun 11, 2020 | 07:14 AM
Honez2323's Avatar
Honez2323
Default Don’t do it.
Be aware the muliplexing systems are different between the two trucks. They will not talk to each other. Different terminal resistance in the pcm and different number of wires and speed.
Old Jun 11, 2020 | 09:12 AM
Moparite's Avatar
Moparite
Watched a hemi swap in a ramcharger last weekend on fourwheeler the tv show. They used a harness with the factory ECM but didn't go into details. They said It would get it to "run". I think you may have more of a problem with the frame swap. Why not use the 97 frame and body? Lot easier.
https://www.motortrendondemand.com/d...ne-swap/33244/
Old Jun 11, 2020 | 08:47 PM
Ramman18's Avatar
Ramman18
I don't know why anyone would want to swap to an engine that's designed to starve itself of oil and grenade. Ever heard of Hemi tick? Cam failures? Lifter failures? Every engine has this flaw. I won't even say good luck.
Old Jun 11, 2020 | 09:28 PM
MoparFanatic21
https://www.youtube.com/watch?v=dI93-Zdx_nY
That's only a problem on the 4th gens. The Hemis make way more power than a 360 could dream of. Not to mention better ignition system and fuel mileage
