transfer case issue?
Old May 11, 2010 | 04:18 PM
ram15006inch's Avatar
ram15006inch
Question transfer case issue?
ok when I have my truck in 4 low and try to go to 4 high my t-case grinds like hell and yes I know i have to stop the truck and put it in neutral before I can do anything with the t-case but every single time I go from 4 low to 4 high its grinds like hell and I was hoping someone on here could tell me why because it bugs me
Old May 11, 2010 | 04:39 PM
dhvaughan's Avatar
dhvaughan
how are you doing the shift ?
there are no synchronizers (sp?) so if you shift slow, or pause, you're stuck.
the right way to shift is to come to a stop, or near stop. trans in neutral, and shift the sob as hard and fast as you can, all the way through neutral. do not pause.
the only other way to shift is to turn it off, shift, then start it back up. if you get stuck in neutral, you pretty much have to do this.
Old May 11, 2010 | 05:46 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
well put
Old May 11, 2010 | 06:24 PM
ram15006inch
ive tried shifting it fast slow everything and it still grinds like all hell the only thing i havent tried is turning it off then shifting out of 4 low all i know is its very very aggrivating
Old May 13, 2010 | 09:07 AM
ram15006inch
bump......... anyone else have any input on what it could be and/or how to fix it?
Old May 13, 2010 | 09:16 AM
Install a transfer case that has synchronizers? Not sure which one that would be though.
Give the shutting off the engine trick a shot.
Not sure if putting the trans in park would work or not. (hold truck in place with brakes, not trans.....)
