Trans filter extension for 46RE
Old May 12, 2010 | 09:12 AM
gipperkid's Avatar
gipperkid
Default Trans filter extension for 46RE
Recently I got a B&M aluminum trans pan for the 46RE. The filter extension it came with is a 3-hole aluminum block. But my original filter only uses two bolts. I don't see how I can bolt it to the valvae body. Does anyone have experience with the B&M pan, part no. 10280.
Here is pic of what came with the pan:
Old May 12, 2010 | 09:57 AM
does the adapter bolt to the trans, and then the filter bolt to the adapter??
If there is a part number with it, I would call the folks ya got it from, and verify the application is correct.
Old May 12, 2010 | 10:13 AM
tango-52's Avatar
tango-52
There is a third bolt, but it is just on the valve body, not through the filter. That way, next time you change the filter you don't have to mess with the extension. I was going to put one of these on when I added the deep pan to my 2001 last week, but the bolts that came in the kit were actually shorter than the stock bolts. I need to get bolts that are about 3.5 inches long for it to work.
Old May 12, 2010 | 10:23 AM
gipperkid's Avatar
gipperkid
Use the three bolts circled in the pic?
Old May 12, 2010 | 03:29 PM
tango-52's Avatar
tango-52
Correct.
