Grinding noise in front,NOT WHEEL BEARINGS
to test u-joints, with the truck sitting still, grab hold of the inner half of the u-joint and twist back and forth. there should be no movement at all in the joint. if there is a little bit of movement, it will make a clicking sound. if there is a lot of movement it will make a clacking sound. either one means its shot. you can drive a little more on a click. i would not drive much on a clack...
very easy to test, don't have to jack it up or anything, just slide under the door and its right in front of you.
