cruise control help
Old May 25, 2010 | 10:43 PM
  #21
Gary-L's Avatar
Gary-L
Veteran: Navy
Well, I've figured there's something shorting in the steering column, which is causing my problem. A few weeks ago, I replaced a blown fuse for the horns and this morning I noticed that the horns aren't working again. I'm betting the fuse blew, so I guess I'll have to tear into the column and track down a short.
Old Jun 15, 2010 | 08:37 AM
  #22
Gary-L's Avatar
Gary-L
Veteran: Navy
Just an update and an FYI - I repaired my Cruise Control yesterday.
As I previously explained, it got to the point where I could turn the Cruise On, but after a moment or two it would turn Off, after which it would not turn on again. Also, assuming it stayed On I could not Set the speed. Some issues leading up to this include having had to press very hard on the power button to turn Cruise Control On.
After a great deal of thinking, I bought a Borg-Warner replacement at O'Reilly Auto Parts for $47. A three minute swap later, and voila -- barely pressing the On/Off button turns the system On. Barely pressing either the Set or Resume buttons immediately activates either function.
So, just some food for thought if anyone out there is having Cruise Control issues.
Old Jun 15, 2010 | 10:22 PM
  #23
dodgeman2289's Avatar
dodgeman2289
my cruise control doesnt engage but my light comes on!
Old Jun 16, 2010 | 10:11 AM
  #24
Gary-L's Avatar
Gary-L
Veteran: Navy
If the vacuum hose can be ruled out, there's a chance it's the switch.
Old Jun 16, 2010 | 11:19 AM
  #25
J415's Avatar
J415
Originally Posted by foxea
Can someone tell me if you step on the brake and turn the cruse control on, does the light come on. I'm thinking maybe a bad brake switch?
If you have a haynes manual and a volt meter, there's a pretty easy way to check if it's good or not.
