cruise control help
Old May 19, 2010 | 11:39 PM
foxea's Avatar
foxea
Default cruise control help
Trying to fix my cruse control. This is what I have done so far. I had a donor truck so all the parts I changed were from there. I replaced the vacuum under the battery box because the vacuum hose was cracked. I replaced the controls on the steering wheel, changed the clock spring and I still get nothing. I do not get a light on the dashboard to turn it on. What do I need to look at or trying swapping out. My horn does not work either, but I do hear the relay under the hood clicking. Must be the horns or wires or a grounding issue, plan on checking that tomorrow. I did change the horns from my donor truck too because one of then was broke and the other one was missing. And yes, I did check the fuse too.
Thanks for all your help, I have almost all the stupid little things fixed on this beater.
I have fixed a lot of things on this truck, but the following things the things you guys helped me with.
Replaced my plenum plate and gasket
Oil presser switch
Speed sensor in rear axle
Temp switch
Cutting off the tab on the thermostat housing
Poor-mans TB mod
And a lot of trouble shooting.
The last thing I have to still do besides the horn and cruise control is replace the front axle seal, passenger side. I have read the DIY and hopefully I can get to it in a few weeks. Looks pretty simple.
Thanks again.
Old May 20, 2010 | 07:10 PM
foxea's Avatar
foxea
Checked my horns today, wires check out 12 volts at the plug. Hooked the horns directly up to the battery, Horns are junk. Will have to find some new ones. Still cant figure out what is wrong with the cruise control.
Old May 20, 2010 | 09:27 PM
Hammer Down's Avatar
Hammer Down
Does the cruise control have a relay that could be faulty?
Old May 20, 2010 | 09:59 PM
Do you have the steering wheel controls? On mine, when I turn the cruise on (not set it mind you) a lite comes on in the steering wheel where there is no button. Do you get that lite?
Old May 20, 2010 | 10:02 PM
mrfarrell's Avatar
mrfarrell
more info...standard or auto? does it light up on the steering wheel?have you checked all the fuses?does anything else not work?
Old May 20, 2010 | 11:13 PM
foxea's Avatar
foxea
It is a auto transmission, The controls are on the steering wheel. I get no light on the dash or the steering wheel. The one I have, it looks like there is 4 buttons, but one is a fake button. It has never worked since I have owned it. I have checked the fuses, all good. Everything else I got working, except the overdrive button, I can turn it off, but the only way to get it back on, is to turn off the truck. I'm pretty sure the two are not related. Horn does not wok, but the horn is junk.
Old May 20, 2010 | 11:25 PM
mrfarrell's Avatar
mrfarrell
it should light up on the steering wheel when you press on..perhaps something under the kickpanel is unplugged?do you have an aftermarket alarm?
Old May 20, 2010 | 11:37 PM
foxea's Avatar
foxea
No alarm, I guess I should check the pins to see if I am getting power. Anyone got a wiring diagram of the switch. I think the one in the Merry Christmas file is different. I think they changed them by then.
Old May 21, 2010 | 12:00 AM
mrfarrell's Avatar
mrfarrell
actually now that i think of it..its probly your neutral safety switch(or whatever you call it on an automatic)..id check that out..iv heard of people not being able to use cruise because there computer still thinks its in park..
Old May 21, 2010 | 01:06 AM
foxea's Avatar
foxea
Now that could be a possibility, were is it located and how do you check it.
